Electronics => Electronics => Topic started by: Private Reid on April 25, 2008, 08:55:51 PM
Title: ...Pin 7? $50 robot
Post by: Private Reid on April 25, 2008, 08:55:51 PM
hi all
i have noticed in the schematics of the $50 robot it has 3 purple coloured dots on the microcontroller (pin 7, Pin 21 and Pin 20) So which one is the correct Pin 7
The one I have to plug the following into:
Small Capacitor
Led
Photoresistors
Regulator
ICSP
Can i plug those components into either one of the pins (7, 21, 20)
Next to pin 21 it says (Pin 7)
Do I have to plug everything into that
Note:  I say plug because i am using a breadboard
Title: Re: ...Pin 7? $50 robot
Post by: Webbot on April 25, 2008, 09:10:31 PM
The three pins you mention all represent the +ve power supply coming from your 5v regulator. You should find they are all wired together - which is why they have the same coloured dot. So it doesn't matter which pins you connect the devices to. If you are using a 9v battery and a 4 AA pack you may find the attachment in this post of use http://www.societyofrobots.com/robotforum/index.php?topic=3292.0 (http://www.societyofrobots.com/robotforum/index.php?topic=3292.0)
Post by: Private Reid on April 25, 2008, 09:15:01 PM
I'm using 6v pack...
Also ground and ground (GND)
Must i connect them together?, like Admin has done in the tutorial?
