Software => Software => Topic started by: Webbot on August 13, 2008, 06:52:15 PM
Title: Eagle Terminal Blocks
Post by: Webbot on August 13, 2008, 06:52:15 PM
This may be more of an 'Eagle' question - but am posting it here as you folk may understand it more.
I'm trying to do an Eagle schematic for a motor driver and am looking for a generic 2 and/or 3 pin connector with a screw - to connect a motor lead to the board. This is a very common part but I cannpt - for the life of me - find it in the Eagle libraries.
Assuming the right hand side of this page is from 'Dimension Engineering' then its those green connectors in the middle diagram !!
Does anyone know where they are located within Eagle?
Title: Re: Eagle Terminal Blocks
Post by: Ro-Bot-X on August 14, 2008, 05:28:45 AM
They are called Wago Screw Clamp.
You will find them in the con-wago-508 library, device W237-2P or 3P.
Post by: Webbot on August 14, 2008, 03:15:44 PM
Thanks !!
Post by: madsci1016 on October 21, 2010, 01:47:32 PM
Grr, I'm trying to find a library for 3.5mm spaced blocks. It seems the Wago library only has 5mm. Anyone see one for 3.5mm blocks?
Nevermind, I guess SFE has it, I just don't like the silkscreen.
