Electronics => Electronics => Topic started by: dsheller on August 27, 2008, 12:40:02 AM
Title: Servo Calibration
Post by: dsheller on August 27, 2008, 12:40:02 AM
I'm curious how you all calibrate your servos to run close to the same speed per pulse... I'm talking about continuous rotation servos.
I bought a couple parallax continuous rotation servos a little ago and just started using them, I noticed they were off through initial testing... so I hooked up a cardboard wheel and marked a position, I then let it run for 10 seconds and count how many rotations I get for that pulse width.
What do you guys do?
Title: Re: Servo Calibration
Post by: Captain_Tuna on August 27, 2008, 03:43:57 AM
the should have a trimmer on one side. you need to rotate that to calibrate them, well...that's what i did.
Post by: dsheller on August 27, 2008, 04:49:12 AM
I'm aware of the trimmer, I set both servos to idle at 1.5 ms pulse width, but the servos -- for whatever reason -- don't respond close enough to drive straight if they were both being given the same pulse.
Post by: Captain_Tuna on August 27, 2008, 05:43:55 AM
i don't think there's much to do then... i mean, it's the same thing that happens with standard dc motors, there's always one that has one more loop of coil than the other one. To overcome that obstacle i just set them at different pulses (i've also seen some other guys do this). But maybe someone more expert than me has a better solution.
Post by: dsheller on August 27, 2008, 07:53:31 AM
Yeah that's what I ended up doing, just going through the range of pulses the servo accepts and writing down their revolutions. Then I just use the closest matches in my code, kind of a dirty method, but I'll keep using it until someone suggests something better.
Post by: Admin on September 01, 2008, 04:36:57 PM
I've never found this to be a problem.
For a robot with closed-loop feedback, sensors will detect and correct for speed imbalances in software.
