Software => Software => Topic started by: anir_n on September 08, 2008, 02:39:12 PM
Title: problem with isp
Post by: anir_n on September 08, 2008, 02:39:12 PM
hi,
i am using a p89c51rd2 mc board and using  flash magic to burn it... sometimes its burnig sometimes not ....there is some problem with the circuit as when i put the mc in some other circuit its burning easily by flash magic then...wat can b the problem with my circuit plz help
Title: Re: problem with isp
Post by: ankit_ipu_niec on September 09, 2008, 08:40:24 PM
If you can send the picture or ckt diagram and explain ur problem in detail than i can might help u.
Post by: ankit_ipu_niec on September 09, 2008, 09:09:22 PM
hey here is the link of an isp works similar to flash magic
http://www.triindia.co.in/download/TRI ISP.MSI
 (http://www.triindia.co.in/download/TRI ISP.MSI)
Post by: anir_n on September 18, 2008, 04:58:05 AM
but i have made the circuit referring that diagram only.... but the problem is still there....
i am using the TRIC as my IDE and flash magic to burn my micro controller . the problem is still there
Post by: Admin on September 19, 2008, 08:50:47 AM
Check over your circuit with a voltage meter.
Make sure your batteries are freshly charged.
Look for loose connections.
http://www.societyofrobots.com/robot_faq.shtml#circuit_debug
