Electronics => Electronics => Topic started by: Trumpkin on October 22, 2008, 08:27:27 AM
I would like to use a mosfet on my next project for reverse voltage protection. What mosfet would be the best?
Whats the application?
Whats being protected from what?
Microcontroller.
An Atmega32 and L293d from me sticking the battery in the wrong way.
just use a Schottky diode
Although a diode would certainly do the job, it would also drop the voltage and dissipate that energy as heat - undesirable for a motor circuit.
Schottky diodes have a low voltage drop
The Schottky diode (named after German physicist Walter H. Schottky; also known as hot carrier diode) is a semiconductor diode with a low forward voltage drop and a very fast switching action.
Low is relative. A typical Schottky diode has a 0.3V drop. My point was that that 0.3V drop does occur and it wastes energy. This energy waste is probably no big deal for an electronics feed or a small servo, but it can add up for a motor circuit feed. A MOSFET has a much lower voltage drop than a diode.
Electrical protection: use a voltage regulator with polarity protection
Mechanical protection: set the pins up so that if the bat is plugged in backwards, nothing will happen
Labeling: mark clearly what wire goes where, use colored wiring too
Labels only help when applied correctly, my team labels things backwards all the time and I seem to recall an arm project of Admins that did the same...
