Software => Software => Topic started by: Rothman85 on November 10, 2008, 01:15:07 AM
Title: Hamamatsu UV Tron pulse
Post by: Rothman85 on November 10, 2008, 01:15:07 AM
I am a final year student in polytechnic and currently enrolled in diploma in mechatronics engineering. My fellow team member have picked to create a flame extinguishing robot. The problem is I can't find an example of project that implied this sensor(HAMAMATSU UV TRON) and I'am using an ATMEL C80951 Microcontroller to handle the control. I'am programming this robot using .HEX file that I created by using Notepad to create the .ASM file. Does anyone know how to use a pulse in programming using assembly code?Anybody?
This is an example of program that I created this program is used to provide the robot with wall evasion manuever:
   CPU   "8051.tbl"
   incl   "8051.inc"
   org   0000h
START:     JB P1.0,START ;JNB=A-High JB=A-Low
      MOV A,#11111010b  ;can be changed to any initial segment
      MOV P0,A
sensor1:   JB P1.3,sensor1 ;press to start shifting display
foward:    MOV P0,A
      ;MOV A,P0
      ;JNB P1.3,brake  ;JNB=A-High JB=A-Low When IR sensor hit a wall the motor start to brake and reverse afterwards
brake:   Mov P0,#11111111b
      call delay
      call delay
      call delay
      call delay
      call delay
      call delay
      call delay
      call delay
reverse:   mov P0,#11110101b
      call delay
      call delay
      call delay
      call delay
      call delay
      call delay
      call delay
      call delay
      call delay
      call delay
      mov P0,#11111111b
      call delay
      call delay
      call delay
      call delay
      call delay
      call delay
      call delay
      call delay
      mov P0,#11111010b
      JMP sensor1
Delay:   MOV   R0,#255
LOOP1:   MOV   R1,#255
LOOP:      DJNZ   R1,LOOP
      DJNZ   R0,LOOP1
      ret
      end
Title: Re: Hamamatsu UV Tron pulse
Post by: sdavis6736 on November 10, 2008, 03:46:41 AM
First you need to set the port, then the data direction register for that port to an output.  Then use the bset and bclr commands.  There are quite a bit of assembly language tutorials on the net.  Check them out, they are very helpful.
