Software => Software => Topic started by: Commanderbob on November 27, 2008, 01:52:34 PM
Title: for loop not stopping?!?
Post by: Commanderbob on November 27, 2008, 01:52:34 PM
I have spent 2 1/2 hours trying to figure this out...
I have an ultrasonic sensor mounted on a servo and I am trying to write a function that scans from right to left, then when it is called again from left to right. Pretty easy right? Sure if the code ran how it should. For some reason when it scans from right to left the for loop does not stop.
for (counter=0;counter<15;counter++)It continues to count forever. Here is the whole code. The function is near the bottom.
#include <avr/io.h>
#include <util/delay.h>
#include <stdio.h>
#include <math.h>
#include <avr/interrupt.h>
#include "hardware.h"
void init_hardware (void);
void USART_Transmit( unsigned char data );
uint16_t a2d_10( uint8_t Channel );
uint16_t ultra_sonic (void);
uint16_t get_ultra_sonic (void);
void debug (char *str);
void us_servo (int8_t deg);
void scan (void);
uint8_t learn_motor (void);
volatile uint16_t interrupt_timer=0;
uint8_t motor_f=0, motor_r=0;
uint16_t log_scan[10][17];
int8_t current_deg=0;
char text[20];
//volatile int8_t current_deg=0;
ISR (TIMER2_OVF_vect)
    ++interrupt_timer;
    PORTA=0;
    DDRA=0;
    PORTB=YELLOW_LED_MASK;
    DDRB=YELLOW_LED_MASK;
    PORTC=0;
    DDRC=0;
    PORTD=0;
    DDRD=0;
    PORTE=0;
    DDRE=MOTOR_MASK|SERVO_WHEEL_MASK|SERVO_IR_MASK;
    PORTF=0;
    DDRF=0;
    PORTG=BLUE_LED_MASK|RED_LED_MASK;
    DDRG=BLUE_LED_MASK|RED_LED_MASK;
    TCCR3A=0b10101010;
    TCCR3B=0b00011010;
    ICR3=40000;
    OCR3A=US_SERVO_CENTER;
    OCR3B=3000;
    OCR3C=3000;
    TCCR1A=0;
    TCCR1B=2;
    TCCR2=3;
    TIMSK=64;
    sei();
    ADCSR = (( 1 << ADEN ) | ( 1 << ADSC ) | ADC_PRESCALAR_128 );
    ADMUX = (( 0 << REFS1 ) | ( 1 << REFS0 ));
    if (((( 1 << ADEN ) | ( 1 << ADSC ) | ADC_PRESCALAR_128 ) & ADCSR ) != 0 )
        // Wait for the initial conversion to complete. This initializes
        // the ADC.
        while (ADCSR & ( 1 << ADSC) )
    UBRR0H = UBRR0_INIT >> 8;
    UBRR0L = UBRR0_INIT & 0xFF;
    UCSR0A = UCSR0A_INIT;
    UCSR0B = UCSR0B_INIT;
    UCSR0C = UCSR0C_INIT;
/* Wait for empty transmit buffer */
while ( !( UCSR0A & (1<<UDRE0)) );
/* Put data into buffer, sends the data */
UDR0 = data;
    uint8_t x=0;
    while (str[x]!=0)
        USART_Transmit(str[x++]);
    // Select the channel in a manner which leaves REFS0 and REFS1 un touched.
    ADMUX = ( ADMUX & (( 1 << REFS1 ) | ( 1 << REFS0 ))) | Channel;
    // Start the conversion
    ADCSR = ADCSR | ( 1 << ADSC );
    // Wait for it to complete
    while ( ADCSR & ( 1 << ADSC ));
    return ADC;
} // a2d_10
    uint16_t fcap=0,scap=0,dist=0;//fcap stores first capture, scap stores second
    ULTRA_SONIC_OUT;//set pin to output
    ULTRA_SONIC_SET;//set pin to high
    _delay_us (10);//delay for a pulse
    ULTRA_SONIC_RESET;//set pin low
    ULTRA_SONIC_IN;//set pin to input
    Clear_ICF1;//clear the capture flag
    TCNT1=0;//set timer 1 to 0 to prevent overflow
    ULTRA_SONIC_CAP_RISING;//capture the rising edge of the pulse
    while (ICF1_Empty)//wait for capture
        if (TCNT1>50000) return 0xFFFF;
    fcap=ICR1;//save the captured value
    ULTRA_SONIC_CAP_FALLING;//capture the falling edge of the pulse
    scap=ICR1;//save the captured value
    dist=scap-fcap;//subtract the timer values to find the pulse lenght
    dist*=0.0850725;//convert to mm
    return dist;
    uint16_t dist;
    dist=0xFFFF;
    while (dist==0xFFFF)
        dist=get_ultra_sonic();
        _delay_ms(10);
    return dist;
    int16_t change;
    current_deg=deg;
    change=deg*22.22;
    change=US_SERVO_CENTER+change;
    if (change<US_SERVO_MIN)change=US_SERVO_MIN;
    if (change>US_SERVO_MAX)change=US_SERVO_MAX;
    sprintf(text,"%i     %i     %i\n\r",change, US_SERVO_MAX,US_SERVO_MIN);
            debug(text);
    OCR3A=change;
void turn (int8_t deg)
    int16_t change;
    change=deg*15;
    change+=300;//offset for the motor to speed up and the servos to move
    OCR3C=2800;
    if (change>0){
        OCR3B=TURN_SERVO_MAX;
        for (;change>0;--change)
            _delay_ms(1);
    else
        OCR3B=TURN_SERVO_MIN;
        for (;change<0;++change)
            _delay_ms(1);
    OCR3B=TURN_SERVO_CENTER;
    OCR3C=3000;
void scan (void)
    int8_t counter=0,countert=0;
    debug("scanning\n\r");
    for (counter=0;counter<9;++counter)
        for (countert=0;countert<17;++countert)
            log_scan[counter][countert]=log_scan[counter+1][countert];
    /*if ((current_deg!=-80)||(current_deg!=80))
        us_servo(-80);
        _delay_ms(500);
    if (current_deg==(-70))
        for (counter=0;counter<15;counter++) <========This works fine?!?
            us_servo((-70)+(10*counter));
            _delay_ms(1000);
            log_scan[9][counter]=ultra_sonic();
            sprintf(text,"%i\n\r",current_deg);
            debug(text);
    else
        for (counter=0;counter<15;counter++)    //<============================================Problem occurs here!
            us_servo(70-(10*counter)); //commenting this line out makes it work
            _delay_ms(1000);
            log_scan[9][16-counter]=ultra_sonic(); //same thing for this line
            sprintf(text,"%i     %i\n\r",current_deg, counter);
            debug(text);
    uint16_t ultra_base=0, tmr1_base=0;
    us_servo(0);
    OCR3C=3000;
    _delay_ms(1000);
    ultra_base=ultra_sonic(); //get the base reading
    interrupt_timer=0;
    LED_ON(YELLOW);
    OCR3C=2800;
    tmr1_base=interrupt_timer;
    while (ultra_sonic()>(ultra_base-100));
    motor_f=interrupt_timer-tmr1_base;
    OCR3C=3000;
    _delay_ms(1000);
    LED_ON(BLUE);
    interrupt_timer=0;
    OCR3C=3200;
    while (ultra_sonic()<ultra_base);
    motor_r=interrupt_timer-tmr1_base;
    OCR3C=3000;
    _delay_ms(1000);
    return 1;
int main (void)
    init_hardware();
    _delay_ms(50);  //allow things to settle
    while (1)
        scan();
        _delay_ms(1000);
Commenting either of those two lines makes the for loop work properly. Also making the loop start at 2 (or higher) instead of 0 works too. I am stumped. I even tried a while loop and got the same problem. It seems that if ct is used in the loop is messes it up because
log_scan[9][0]=ultra_sonic(); works.
I really appreciate any help. I am completely confused.
This code is for an ATmega128.
Title: Re: for loop not stopping?!?
Post by: Webbot on November 27, 2008, 02:48:00 PM
You could try increasing the size of your text array used by the sprintf commands. Currently it is only chars long and it looks as though some of the sprintfs may write a longer string than that. In which case it could be accidentally 'zapping' some other variables.
Post by: Commanderbob on November 27, 2008, 03:14:46 PM
I had the problem before I added the sprintf command. I added those to see why the servo was freaking out and not exiting the scan function. Changing the size and removing the sprintf command has no effect.
Post by: Commanderbob on November 27, 2008, 10:31:33 PM
Apparently it was the optimizer. It was set to s to save space and that made it not work. Also setting it to 2 makes it not work. At 1 everything is fine.
Post by: Admin on November 30, 2008, 02:30:39 AM
I just turn off the optimizer because of these problems. If you don't run out of memory, and don't require super fast code, there is no reason to keep it on.
Post by: Webbot on November 30, 2008, 04:05:23 PM
Would be good to report to your compiler creator as a bug report. We need to learn to that optimisation should work rather than 'just turn it off' which lets them off the hook. Think your code is complex - try writing a compiler!
Post by: paulstreats on November 30, 2008, 06:08:18 PM
I wonder if putting a return type at the end of the loop might prevent the optimisation error?
