Electronics => Electronics => Topic started by: arpita on December 13, 2008, 02:10:31 AM
hie-
i am new to the field of robotix-first year IT undergrad
i have a project to do-
Problem Statement: To make an autonomous guided vehicle which can navigate on a road, stopping at zebra-crossing, following traffic lights and reaching an end point.
specifications-• The dimensions of the bot cannot exceed 1.5m x 1.5m x 1.5m.
• The bot must be autonomous and must not have any manual intervention during its run.
• Wired communication between bot and Processor is allowed . However there would be no power outlets in the arena. So you need to bring you own power supply / batteries to run the bot.
• The bot should have provision for a button to stop the bot.
• Mounting of a laptop or any kind of hardware on the bot is allowed.
• The robot is allowed to have external light sources on board, e.g an on board flashlight or headlight. However the flashlight cannot be toggled, (i.e shut on and off) manually during the run.
• Bot should be able to operate under all conditons of weather.
• Any type of sensor e.g camera is allowed for the robot.
tel me how to go about it?
what shud be the best batteries to be used?
keep in mind suggest onli cost effective ones
how to interface the hard ware and software??????
plz help.
thanks in advance.
First read this link
http://www.societyofrobots.com/robot_tutorial.shtml
Then check the way admin made the 50$ robot {the programming bit helps u to interface hard ware and software too}
http://www.societyofrobots.com/step_by_step_robot.shtml
Then see how to make an autonomus bot
http://www.societyofrobots.com//robot_sumo.shtml
And for the batteries check out this post
http://www.societyofrobots.com/batteries.shtml
Thi post shows member pages, to help you for the signal and zebra crossing stuff
http://www.societyofrobots.com/member_tutorials/
Hope this helps {If there is anything nonsensical i hv written, dont blame me im a kid}
Best of luck!
PS. even i would write like that, but if you write such english, the people would find it tough to search your questions!
hi,
Right now i dont have any idea, but can you tell me where this competition is held...... iam from India and like to take part in robotics events...
BEAMer
Ye,
I would also like to know, I am from India too
