Mechanics and Construction => Mechanics and Construction => Topic started by: geek1 on December 25, 2008, 10:28:30 AM
Title: good construction material
Post by: geek1 on December 25, 2008, 10:28:30 AM
Does anyone know a construction material that you can cut with hand tools? I ordered some of this stuff called Sintra from Solarbotics.com, it says you can cut it with hand tools, not really sure how durable though.
I am a new roboticist
Title: Re: good construction material
Post by: bryan922 on December 25, 2008, 12:45:46 PM
Maybe delrin, or check out this article: http://www.societyofrobots.com/materials_hdpe.shtml
Post by: geek1 on December 25, 2008, 02:36:20 PM
thanks, but where do you get the delrin you mentioned?
Post by: bryan922 on December 25, 2008, 03:18:37 PM
If you need aluminum, delrin, felt, rubber, ceramics, wax, magnets, bushings, bearings, pins, ball joints, clamps, lubricants, valves, tubing, hose, fittings, nuts, bolts, washers, pumps, cable, sleeves, springs, motors, switches, buttons, knobs, couplings, shafts, rod, connectors, etc. in almost any conceivable size, configuration, and specs, drawings, dimensions on said products, then you should try mcmaster-carr at mcmaster.com (http://mcmaster.com).
Post by: bulkhead on December 25, 2008, 05:18:25 PM
You can quite easily cut 1/16" and 1/8" aluminum extrude (available at Home Depot, Lowes, other hardware stores) with a hacksaw, metal file, and vise.
Post by: geek1 on December 25, 2008, 06:30:43 PM
thanks all! there is obviously a great community here! the best forum I ever joined  ;D ;D
Post by: jamort on December 26, 2008, 11:29:28 AM
sintra ios fine up to like three pounds also reinforece it....
