Electronics => Electronics => Topic started by: Hawaii00000 on January 07, 2009, 01:27:24 AM
Shouldn't the ATmega8 in the $50 robot have more connections for sensors and servos? In the circuit admin build, there's not that many. Can't the ATmega8 support more?
Yes it can, plug in more servos/sensors on the other ports.
Solder in the extra header pins to fill in the missing port
yes the atmega can support more the only thing about more motors is i dont know if i d try to add another one on to such a rigid base
Hi jamort - not quite sure what you mean by 'such a rigid base'. Do you mean choice of power supplies?
i think hes talking about adding more servos to a cardboard robot
Ok - thats simple. Chuck away that 25 cent pizza cardboard base. Check out the forum for HDPE or similar. Build a 'real' base for a few $. Problem solved.
that or you could simply use the board for something else keep the electroncis
How many more... when I say "more servos" I mean soldering on more connections for servos/sensors not just plugging in more, because I know there are some free ones. Once those are used up are there any options.
