General Misc => Misc => Topic started by: noah on January 21, 2009, 10:01:36 AM
Title: Help, please. Radio frequencies...
Post by: noah on January 21, 2009, 10:01:36 AM
I have a question about frequencies.  The rules of this science contest I'm doing says:
 "only commercial radio control equipment intended for unlicensed remote control vehicle operation may be used. For example, transmitters whose operational frequencies are in the 75 MHz band, 27 MHz band, 49 MHz band or the 2.4 GHz band. Robots may not use equipment that requires a license to operate."
I have found some remote controls that have a 72 MHz frequency. Would this work or would it be against the rules?  Can I alter the frequency of a transmitter?
Thanks for all your help!
Noah
Title: Re: Help, please. Radio frequencies...
Post by: airman00 on January 21, 2009, 10:04:43 AM
It would be fine(they won't hunt you down) , but if I recall correctly 72 mhz is used for R/C aircraft, so dont control your robot near an R/C airfield
Post by: noah on January 21, 2009, 10:34:01 AM
              thanks!
Post by: Razor Concepts on January 21, 2009, 11:08:50 AM
Technically it's illegal to use 72mhz on anything that operates on the ground, but it's not like anyones gonna know  ;)
Post by: paulstreats on January 21, 2009, 11:12:17 AM
I think 72mhz is reserved for radio controlled helicopters and aeroplanes so just make sure none are in the vicinity when you use it
Post by: TrickyNekro on January 21, 2009, 11:58:26 AM
Get a remote with decryption....
They are more expensive but less prone to cause a disaster....
Also, note that...
It's basically legal to transmit in any frequency as soon as the power of your transmitter do not extent the regulations....
In R/C these limits are far far extended....
Post by: Razor Concepts on January 21, 2009, 02:08:49 PM
2.4ghz is the way to go, you can use it land and air, and there is basically no interference.
Post by: householdutensils on January 21, 2009, 03:21:46 PM
Also, note that...
That's not really true. A good chunk of the radio spectrum is heavily policed, transmitters of any kind need to be licensed to operate on regulated bands.
Companies like Iridium pay millions of dollars for their spectrum licensing packages.
Post by: izaktj on January 21, 2009, 04:16:06 PM
Yeah, just change the crystals on Rx and Tx.
Post by: TrickyNekro on January 21, 2009, 04:27:33 PM
As far as the transmittion doesn't extend from your property it's all right... That's the limits I mean...
If you haven't noticed NOKIA has a cellphone with a about 0.5m fm transmitter...
Was so nice hearing your music in a cab after clubbing, and the driver just to wonder what hit him!!!!
And if you are good with electronics you can basically extend it's range dramatically....
 up to 3 - 4 meter running from the Li-ion battery of the cellphone...
Yes, I'm an original prankster!!! Period!!!
And thing is that I don't live in a country that doesn't suffer from electromagnetic wave pollution...
This means.... that even if I transmit in illegal frequencies, I must cause a problem many times so that I'm reported
then police tries to find who and you are simply noted some times before paying fines....
Unfortunately the bad thing about where I live is that I have a military Radar in the view field of my balcony...
So..... This makes it pretty easy to find me.... :P
But who cares.... You can transmit your VHF for your plane..... and never get caught.... :D
Post by: householdutensils on January 21, 2009, 04:46:15 PM
In any country with an established spectrum management policy, even on your own property it would be illegal to use regulated bands. Regardless of the range of the transmitter. Though the spectrum is pretty broad, we're talking talk back to sat comms, so obviously you're not gonna get in trouble for using little FM Transmitter, but if you've built a base station for communicating with satellites, expect to get a big fine xD
Your totally right though, it's pretty difficult to get caught unless your using some pretty hefty kit that can cause interference.
Post by: cooldog on January 21, 2009, 07:31:50 PM
all the fequenceys
http://www.societyofrobots.com/remote_control_robot.shtml#RFrefchart
Post by: noah on January 21, 2009, 08:43:01 PM
I think I "get it" about the different frequencies being used for different types of robots--flying, surface etc.  And I am fairly certain that the contest will require that I operate at a surface frequency--i.e. the 75 MHz.  I am waiting to hear from the officials (by the way, has anyone ever participated in this thing called the Science Olympiad??? It's pretty cool).
How easy is it to change the frequency crystal to switch a 72 to a 75?  From my research it looks as simple as popping one out and switching it with the desired one.  Am I right?  The reason I ask is that I've found some reasonable priced 72 transmitters on e-bay and Tower Hobbies.  I'd appreciate any feedback and again, I am very grateful for all you've shared over the past couple days.  You rock!
        Noah
Post by: cooldog on January 21, 2009, 08:45:26 PM
yes it is
Post by: Razor Concepts on January 21, 2009, 09:23:57 PM
No you can't switch crystals to run on 72 or 75. You can switch between the specific values (ie, 72.012 to 72.022 or something like that), but you cannot interchange 72 and 75 crystals.
Post by: Admin on January 31, 2009, 09:15:51 PM
The judges will probably check the frequency written on your crystal in your transmitter.
