General Misc => Misc => Topic started by: frodo on February 09, 2009, 02:39:53 PM
hi, i took apart a computer mouse and ripped out the wires before thinking. now i don't know which wire goes where. it still has the computer connector on the other end so i was wondering whether you guys know of anything i can do with the wires (please don't say chuck them in the bin).
Do you by any chance have a model number for the mouse? That might help get some answers
i don't actually because the case of it went in the bin and its from about 15 years ago :(
@Frodo - are you asking 'how do I put the mouse back together?' or 'what can I use wires for?' ;D
If you are asking is you can use the connector and want to know which pin on the connector goes to which wire, the use a multimeter to check each pin with each wire. If you don't have a multimeter, create some small circuit with a lamp or LED and use that.
@ jka
how will a lamp or an LED work? it will only test connectivity, won't it?
@ jka
What do you want exactly? Use the wires? Use the connectors?
Yeah.
You could use the wires to create a sort of quick disconnect thing on one of your robots if you get a female port to plug the connector into. Solder the port onto your robot board and hook the other wires up to a Serial jack or something.
you lost me with that in the first line Dragon, and i haven't actually built a robot.
