Electronics => Electronics => Topic started by: z.s.tar.gz on February 27, 2009, 08:29:35 PM
I want to use a different MCU than the one used in the $50bot. How hard is is to change the sor_utils.h file to my new pin configuration? I'm thinking of an atmega644.
Does ponyprog etc work with it?
If I remember right, until.h just include all other needed libraries....
So you have to change the other libraries to meet your IC needs...
But basically... there is a pretty good similarity between MEGA cores....
So I don't even think you have to change something....
Lefteris Greece
I need to change it to accomodate 40 pins, with new pinouts/ins. So, is that simply a matter of changing the names or something harder?
Actually, I'm going to take a look at it and see how much sense I can make out of it.
Edit: I can only understand a little bit. (Java is not very helpful for robots :P)
I'm just going to get a 328p and figure it out as I go.
Answer as far as I can see it: Hard for programming beginners but not impossible.
If you are compiling for a different AVR then just change the device in AVRStudio or your makefile. This will automatically change the definition of all the IO pins to suit that controller.
WinAVR and AVRlib are meant to work with any AVR processor. But this forum and most of the software publish on it is intended for either the ATMega8, ATMega168 or ATMega640.
The utils are easy to change. If you open up the file, you'll see instructions written on how to change it.
So, if I got a 644 all I have to do is change the model and I don't have to change any files?
Otherwise, which files should I take a look at. BTW, I'm trying to this from linux.
Edit: Specifically, I'm trying to use AVRDude.
http://www.societyofrobots.com/step_by_step_atmega168_swapout.shtml (http://www.societyofrobots.com/step_by_step_atmega168_swapout.shtml)
