Electronics => Electronics => Topic started by: BoB_the_BoT on March 07, 2009, 05:11:56 AM
hi
i'm trying to build a 4 channel rf transmitter receiver to transmit 4 data pins from the serial port of the computer to my robo.
Before connecting the serial port pins, i wanted to test the rf circuitry.
i've used the circuits shown in : http://home.att.net/~wzmicro/rf.html (http://home.att.net/~wzmicro/rf.html) .. with the differences that i've connected +3v for the AD pins of encoder (HT12E) that i want to transmit and that i've used the AM 433Mhz transmitter and receiver shown in : http://home.att.net/~wzmicro/rf_xmitter_receiver.htm (http://home.att.net/~wzmicro/rf_xmitter_receiver.htm) , instead of the WZ-X01 and wZ-R01 shown in the circuits.
i've used 3.1v batt (using 2 AA cells) for the transmitter side and 4.8 v batt (3 AA cells) for the receiver side.
Also, for the sake of testing, i had connected 4 LED's to the 4 output pins of the decoder (HT12D). Neither them nor the valid transmission pin (pin 17 of decoder) showed any signs of success. :(
pls help
Your question is too broad. How much troubleshooting have you done? I would test the encoder/decoder separately from the transmitter/receiver. First check if the encoder is outputting data. Then set up the transmitter and receiver pair and input a logic high and low. See what the receiver outputs. Also check the decoder separately. Once you get all that working then connect them together.
[...] to transmit 4 data pins from the serial port of the computer [...]
Even though you haven't done it yet, beware that the serial port use +/-12V signals, so you need a level converter for that.
Are you aware that, in the schematic, it is coupled so the HT12E is powered continuously, but the transmitter is only grounded (through D1 to D4) when a button (S1 to S4) is pressed?
and that i've used the AM 433Mhz transmitter and receiver shown in [...]
I guess you don't have an oscilloscope, which would make it a 5 minute job to find the fault?
If you probe the DOUT-pin of the HT12E with a DMM (in the 20V range Try both AC and DC) what does it read?
You really have to approach your problem in a modularized way. First verify the encoder, then the transmitter, then the receiver and finally the decoder.
thanks u guys...
i'll test each of these components separately like u guys have said and get back..
@soeren
thanks for the facts on serial port voltage and the transmitter grounding ... didn't notice them.
