Electronics => Electronics => Topic started by: Razor Concepts on April 06, 2009, 06:02:31 PM
I've been using transistors to switch on some LEDs. But what I never figured out was the resistor on base to the trigger. Is there some way to calculate that resistance for the load I want to trigger? Can I just use no resistor at all? I've tried no resister with a 2222 but I fried one that way, so I started using resistors from 250 to 1k ohms randomly... and so far they are working fine.
You need to know the current passing through the collecter/emitter ie through your LED and the gain provided by your transistor. A typical value may be a gain of 50. This means that to provide a current of 50ma thru your LED you would need 1ma at the base.
There is a voltage drop typically of 0.6v between the base and emitter so if you are feeding it a 5V signal from your controller then the remaining voltage drop is 5v - 0.6v = 4.4v.
Using R=V / I then R = 4.4V / 1ma = 4.4k ohms
I suggest you use a lower resistor value than calculated above. This will ensure the transistor saturates--. Transistor dc gains drop as collector current increases.
For example from the 2N2222 data sheet:
If the collector current of 150mA , you can get a Vcesat of 300mV with 15mA of base current. This makes the base resistor about 300 ohms if the drive is a 5volt signal. Hopefully the control input can suppply 15 mA.
In above case I would suggest say a 1K resitor-- a balance between saturation and control input loading.
Cheers
