Software => Software => Topic started by: airman00 on April 17, 2009, 09:44:52 PM
Title: UART Output Time
Post by: airman00 on April 17, 2009, 09:44:52 PM
Is the amount of time it takes to send a character out UART a constant?
For example: If it takes me 10uS to send 'A' out UART now, does that mean that it will always take exactly 10uS to send out 'A'?(assuming registers are always cleared before send, etc.)
If its not a constant, how much can it be off by?
Title: Re: UART Output Time
Post by: superchiku on April 18, 2009, 04:06:51 AM
asynchronous comm is synchronized at the bit level...so it will alwayz take the same time...provided the distance remains same...
Post by: Webbot on April 18, 2009, 11:54:25 AM
Yes - the timing on the UART hardware will be the same but, just stating the obvious, the timings in software may be thrown out by other interrupts happening in the background.
ie if it takes 10uS to send one character then it may take more than 100us to send 10 characters as other interrupts MAY stop you feeding the UART fast enough - so there may be some 'gaps' in between each 10uS burst. This will also depend on whether you are feeding the UART in the foreground (character at a time) or from a transmit buffer via transmit interrupts.
Post by: airman00 on April 18, 2009, 06:19:37 PM
gotcha, thanks!
Post by: frank26080115 on April 18, 2009, 11:43:44 PM
This is not true for AVR microcontrollers (I can't comment on others), there's a FIFO buffer to ensure that the stop bit has the exacty same duration as all the other bits, no more no less, unless your software is delayed longer than the time it takes to send 10 bits (8 data, 1 start, 1 stop, so 11 if you are using 9 bit mode).
Your UDR = x statement will place x into the buffer, and if the shift register is empty, it will go immediantly into the shift register and gets clocked out the TX pin according to the downcounter (your UBRR), if the shift register is not empty, then it waits until it is actually empty.
The most important thing to know: The time at which the transmit complete interrupt flag is set is when the byte is moved from the buffer to the shift register, not when the shift register is finished sending the byte.
So be extra careful about changing baud rates during run time, make sure you have a software delay before changing baud rates, because the shift register can still be busy even if the transmit complete interrupt flag is set
