Software => Software => Topic started by: not_this_punk on June 23, 2009, 06:52:48 PM
Title: Controlling 10 servos for a Biped
Post by: not_this_punk on June 23, 2009, 06:52:48 PM
Hello.
OK, so I need to control all 10 servos simultaneously with an ATmega16. Here's how I do it:
- Clock frequency is 16 MHz.
- I set Timer 1 to the system clock (16 MHz), in Fast PWM TOP=ICR1.
- I want the timer to count each passing of 10 microseconds: 1/16 = 0.0625 us (timer1's period). I want 10 us so 10/0.0625 = 160 periods equal 10 us
- In Timer1's interrupt I increment a variable (every 10 microseconds). When it reaches 2000 I set it back to 0.
// Timer 1 overflow interrupt service routine
interrupt [TIM1_OVF] void timer1_ovf_isr(void)
t++;               //increment t every 10 us
if(t==2000)    //20 ms have passed
t=0;      //set t back to 0
per++;  //increment per (I need this in my function)
This is the interrupt of Timer 1: per keeps the number of 20 ms signals.
So basically, I create my own PWM using Timer 1.
In main() I do something like this (but for independent control and speed of 10 servos):
while(1)
{ if(t<150)  //150 means 1.5 ms like I said
                   PORTC.0=1;
                else        PORTC.0=0;
Controlling all 10 servos is just an expansion of that code.
What do you think? Is it OK? I can't use the built-in PWM to control all 10 servos and I don't want to waste precious resources with delays. Is it correct? Are there any better solutions (remember that I have 10 servos to control)?
Title: Re: Controlling 10 servos for a Biped
Post by: Admin on June 23, 2009, 08:19:47 PM
You may find interrupts cause you problems with the UART, if you are using it that is . . . make sure you turn interrupts off when you use it . . .
Post by: not_this_punk on June 24, 2009, 01:46:11 AM
Hello admin, thank you very much for your reply!
Yeah, I never thought about that, but it seems logical now :)
But what do you think about my method? Is there any way to control 10 servos from a single ATmega16 using the built-in PWM? Or...what is the usual way of doing it? I feel like I'm missing something here...I don't want to stress out the MCU for no reason.
So how is it made in servo controllers and MCU's like the Axon?  ???
Post by: Admin on June 24, 2009, 04:40:34 AM
There are three main ways to control servos:
- interrupt method
- delay method
- PWM method
Each method has benefits and drawbacks, and even variations in ways to implement them. The problem with the PWM method is your ATmega16 only has 4 PWM, meaning it can only do 4 servos.
My Axon II will have 16 PWM, but will be several months before it comes out (I'm aiming for early October).
