Mechanics and Construction => Mechanics and Construction => Topic started by: Soulstoler on June 25, 2009, 02:03:25 PM
Title: Can I use Remote Controlled Cars to make robots?
Post by: Soulstoler on June 25, 2009, 02:03:25 PM
Hey.
You can see that I'm new on here forums, so hello.
I'm just asking that can I use Remote Controlled Car to make robot? I have 2x Nikko Power Streak Remote Controlled Cars.
Title: Re: Can I use Remote Controlled Cars to make robots?
Post by: Soeren on June 25, 2009, 04:17:15 PM
Sure you can, a microcontroller "replacing" the R/C-receiver catering for the motors and sensors mounted on the chassis is a good way of learning the basics from.
Post by: Hawaii00000 on June 25, 2009, 11:12:20 PM
Yep, this tutorial uses the circuit from an rc car ( http://www.societyofrobots.com/member_tutorials/node/284 (http://www.societyofrobots.com/member_tutorials/node/284) ) and this one uses the full chasis (http://www.societyofrobots.com/member_tutorials/node/49 (http://www.societyofrobots.com/member_tutorials/node/49) ).
Post by: Joker94 on June 25, 2009, 11:27:03 PM
an r/c car is a great way to start off if you are able to get some good cirucuitry
theoreticaly all you need to do is plug the r/c circuit into a mcu circuit, the $50 board should work
Post by: Soulstoler on June 26, 2009, 12:26:48 AM
Thanks for the answers :), Now I know where to start.
