Software => Software => Topic started by: izaktj on June 29, 2009, 09:33:56 PM
I'm trying to do some programming but I've never programmed with Basice stamp.
The idea is known an simple:
If (right_detect = 1 & left_detect = 0)
Turn left
If (right_detect = 1 & left_detect = 1)
Go backwards 2 seconds
Turn left
If (right_detect = 0 & left_detect = 1)
Turn right
If (right_detect = 0 & left_detect = 0)
Keep going forward
But once in Basic stamp, I don't seem to figure out what is what.
For instance, here is a generic code for the sumobot (test)
' SumoBot-4.2-IR-Scan.BS2
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[ I/O Definitions ]-------------------------------------------------
LMotor PIN 13 ' left servo motor
RMotor PIN 12 ' right servo motor
LfIrOut PIN 4 ' left IR LED output
LfIrIn PIN 11 ' left IR sensor input
RtIrOut PIN 15 ' right IR LED output
RtIrIn PIN 14 ' right IR sensor input
' -----[ Constants ]-------------------------------------------------------
LFwdFast CON 1000 ' left motor fwd; fast
LFwdSlow CON 800 ' left motor fwd; slow
LStop CON 750 ' left motor stop
LRevSlow CON 700 ' left motor rev; slow
LRevFast CON 500 ' left motor rev; fast
RFwdFast CON 500 ' right motor fwd; fast
RFwdSlow CON 700 ' right motor fwd; slow
RStop CON 750 ' right motor stop
RRevSlow CON 800 ' right motor rev; slow
RRevFast CON 1000 ' right motor rev; fast
' -----[ Variables ]-------------------------------------------------------
irBits VAR Nib ' storage for IR target data
irLeft VAR irBits.BIT1
irRight VAR irBits.BIT0
lastIr VAR Nib ' info from last reading
pulses VAR Byte ' counter for motor control
' -----[ Initialization ]--------------------------------------------------
Reset:
LOW LMotor ' initialize motor outputs
LOW RMotor
' -----[ Program Code ]----------------------------------------------------
Main:
GOSUB Read_IR_Sensors
BRANCH irBits, [Scan, Follow_Right, Follow_Left, Hold]
Scan:
BRANCH lastIR, [Move_Fwd, Scan_Right, Scan_Left, Move_Fwd]
Move_Fwd:
DEBUG HOME, "Forward", CLREOL
GOTO Main
Scan_Right: ' spin right, slow
DEBUG HOME, "Scan Right", CLREOL
PULSOUT LMotor, LFwdSlow
PULSOUT RMotor, RRevSlow
PAUSE 20
GOTO Main
Scan_Left: ' spin left, slow
DEBUG HOME, "Scan Left", CLREOL
PULSOUT LMotor, LRevSlow
PULSOUT RMotor, RFwdSlow
PAUSE 20
GOTO Main
Follow_Right: ' spin right, fast
DEBUG HOME, "Follow Right", CLREOL
PULSOUT LMotor, LFwdFast
PULSOUT RMotor, RRevFast
PAUSE 20
lastIr = irBits ' save last direction found
GOTO Main
Follow_Left: ' spin left, fast
DEBUG HOME, "Follow Left", CLREOL
PULSOUT LMotor, LRevFast
PULSOUT RMotor, RFwdFast
PAUSE 20
lastIr = irBits
GOTO Main
Hold: ' on target
DEBUG HOME, "On Target", CLREOL
FOR pulses = 1 TO 3
PULSOUT LMotor, LStop
PULSOUT RMotor, RStop
PAUSE 20
NEXT
lastIr = %00
GOTO Main
END
' -----[ Subroutines ]-----------------------------------------------------
Read_IR_Sensors:
FREQOUT LfIrOut, 1, 38500 ' modulate left IR LED
irLeft = ~LfIrIn ' read input (1 = target)
FREQOUT RtIrOut, 1, 38500 ' modulate right IR LED
irRight = ~RtIrIn ' read input (1 = target)
RETURN
