Software => Software => Topic started by: Kirk on July 20, 2009, 10:55:04 PM
OK, so I know and love avrlib rprintf command (and the vt100 library). I have used it in several projects over a UART.
Now I need to use a parallel LCD.
I got the LCD working using the avrlib LCD library, but not using rprintf. How do I direct the rprintf data to the LCD? What function do I put in rpintfinit?
Does anyone have sample code?
I doubt that \n and \t will work but that is OK.
Kirk
I think you need to write a function such as:
void LCD_printchar(char c){
Then call the appropriate AVRlib methods to output the character
Then call
rprintfInit(&LCD_printchar);
to tell rprintf to call this routine for each byte being output
I dont have a parallel LCD - so thats the limit of my help!
Thanks!
When using AVRlib lcd.c and AVRlib rprintf.c the following links rprintf to the LCD
rprintfInit(&lcdDataWrite); // configure rprintf to use LCD for output
rprintfInit(lcdDataWrite); // this also works. I guess that I do not understand how this really works.
Alas \n does not work.
But the other nice formatting tools like rprintfNum work!
Thanks again for the help.
Kirk
