Software => Software => Topic started by: meiralfasi on July 31, 2009, 08:13:15 AM
Need Help .
I bought Axon Microcontroller , install software and use bootload, i uploaded the Servo center program and when i connect the servo to terminal h2 the servo going from side to side then i connect the servo to any terminal same thing happend.
i use a diffrent servo , the same thing happend .
i downloaded the led switch program and nothing happend maybee i got a bad axon microcontroller I'm lost
any help will be appreciated.
PS . infact any program from the source sample code that i download douse not work when i use bootload the is confermation that the program install successfully.
I had some problems with the premade sourcecode from this site. I also thought the axon unit I got was broken. But it worked programming it. Just try creating something for yourself in AVR studio. It should be pretty easy.
I will greatly appreciate if you post a program that actually works.
This is reticules, why the have example in the website that are not working properly.
Could you post exactly what you typed in the command line to get the program to bootload.
This is the command line for the bootloader fboot17.exe -b115200 -c2 -paxon_ser.hex -vaxon_ser.hex I got conformation I connected the servo to any pin include H2 the servo go to one side and still pulsing it dose that with any pin . I uploaded diffrent program and nothing happend.
double posting, here is my response:
http://www.societyofrobots.com/robotforum/index.php?topic=8706.msg67721#msg67721
