Electronics => Electronics => Topic started by: aruna1 on August 02, 2009, 01:44:13 AM
Title: looking for a IC
Post by: aruna1 on August 02, 2009, 01:44:13 AM
hello
I'm looking for a analogue multiplexer/demultiplexer ic which runs on single selection pin.
for example lets say 4 to 1 multiplexer. when i give
first pulse to its selection pin it connects input1 with output
at second pulse to its selection pin it connects input2 with output
at third pulse to its selection pin it connects input3 with output
at fourth pulse to its selection pin it connects input4 with output
at fifth pulse to its selection pin it connects input1 with output
I'm not sure if this kind of IC exist and i dont know how to call them. ::)
Title: Re: looking for a IC
Post by: SmAsH on August 02, 2009, 03:15:29 AM
i haven't heard of anything like this before but then again i haven't really looked...
you could use a small ic like the attiny13 to accomplish something simple like this...
have you considered doing that?
Post by: aruna1 on August 02, 2009, 03:18:08 AM
avr are hard to find in my country.and PICs are very expensive and has very small selection. :'(
how ever i think we can use a shift register for this but only problem is how to use analog values with it
Post by: SmAsH on August 02, 2009, 03:19:53 AM
what country do you live in?
Post by: aruna1 on August 02, 2009, 03:21:30 AM
sri lanka
Post by: SmAsH on August 02, 2009, 03:23:27 AM
futurlec.com.au claim they will deliver to anywhere in the world for $7aud...
and they have cheap as dirt avr's, what price do you consider to be good for a small ic?
Post by: aruna1 on August 02, 2009, 03:25:31 AM
well i'm not sure i havent buy stuff from abroad before.and i have no credit card.(in sri lanka credit card usage is low) ::)
Post by: SmAsH on August 02, 2009, 03:28:53 AM
damn, that sucks then :-\ ill take a look around to see if any chips i can find fit your description...
if you don't buy from other countries how do you plan on getting the chip?
Post by: aruna1 on August 02, 2009, 03:32:31 AM
well as i said i havent bought any before(never wanted).what i normally do is use alternative stuff.for example i can do this with counte+encorde+demultiplexer.but circuit will be large
Post by: SmAsH on August 02, 2009, 03:37:34 AM
just for reference, futurlec do not require a credit card, they take cheques too :P
http://www.futurlec.com.au/OrderingInformation.jsp
Post by: aruna1 on August 02, 2009, 03:38:47 AM
well i will chk
Post by: jka on August 02, 2009, 04:19:33 AM
Did you find an IC? Check the 4051, 4052 and 4053 ic's. http://www.fairchildsemi.com/ds/CD%2FCD4052BC.pdf. They take a BCD input to select which pin is connected to the output. If you need pulses, you can use a bcd counter like 4510: https://homepages.westminster.org.uk/electronics/4510.htm
