General Misc => Robot Videos => Topic started by: gary_ramsgate on August 11, 2009, 02:45:32 PM
Here's some photo's strung together into a video of my W.I.P
[youtube]http://www.youtube.com/watch?v=vEb9uOdNMUw[/youtube]
wow! that robot looks so good, i just have two questions :P
what mcu did you use as the main "brain" of the bot?
what was the stepper motor for, i understand you used encoders... did you use them with the steppers?
that robot looks excellent,
now all thats missing is information about the robot and a video of it working!
woho gr8 project mahn !!looks are neat and the things used is just awesome .the robot looks are gr8 .
Thanks for the comments.
The main brain of the robot is a VIA EPIA Mini ITX motherboard with a EDEN processor running at 533Mhz. £30 from ebay.
I'm booting the board from a compact flash card and using WIN98 as the OS.
I was originally going to drive the wheels using two stepper motors. Unfortunately the motors didn't have enough torque, so I opted for two DC motors and built my own H-Bridge controller. I may use the stepper motors to control the head of the robot (pan & tilt). The encoders are for the two DC motors.
I've just got to the stage where I am going to write some test software to move the robot around, taking into account the encoder outputs on the two motors.
Then I need to decide on what sensors I need.
very nice. do you have any information on building a bot that runs off of a mini itx board? it's something i'd like to look into.
I am using a Velleman K8055 USB digital/analogue board to control the motors and take feedback from the encoders.
I am also planning on using it to control a couple of stepper motors on the robots pan & tilt head.
The Mini ITX board also has a parallel port, which I will use to interface with a multiplexed AtoD to take in various inputs from whatever sensors I decide to use.
I chose this particular motherboard because of its low power consumption, 7W when idling and 12W under 100% CPU load.
To power the board, i'm using a lead acid battery (3Ah) and a Pico 120W ATX DC-DC converter. This requires a 12v input and gives the necessary output voltages for the motherboard.
bravo!
i thought you weren't using steppers with the encoders, but the pictures confused me...
what kind of objects will you need to detect? and just avoid or identify them?
Very nice robot.
What board do you use to give the sensor data to the PC?
Can you use any old PC motherboard for a robot?
Great robot.
But the real question on everyone's mind is...
How do you keep your workbench so clean? Amazing!
;D
