Software => Software => Topic started by: airman00 on August 28, 2009, 11:07:07 AM
Title: Axon I2C Interface with DS1307 Real Time Clock
Post by: airman00 on August 28, 2009, 11:07:07 AM
I'm attempting to use  the DS1307 clock with the Axon over I2C - http://www.sparkfun.com/datasheets/Components/DS1307.pdf
I've built the circuit they show in the datasheet and the Axon is internally pulling up the SDA and SCL ( I checked)
I do not have access to an o-scope until Monday, but I'd like to get this working over the weekend anyways.
Here is my code:
#define REGISTER              0x00
#define DS1307_ADDR 0x68
#define BUFFSIZE          0x08
int bytes[8];
int i;
rprintfInit(uart1SendByte);  // Set up rprintf to be USB
i2cInit();  //initialize I2C interface
i2cSetBitrate(100);  //set I2C transaction bit rate to 100 kHz
i2cSendStart(); //Send I2C start condition in Master mode
i2cSendByte(DS1307_ADDR | 0x00);    //Send (address|R/W) combination or a data byte over I2C
i2cSendByte(REGISTER);
i2cSendByte(DS1307_ADDR | 0x01);    //Send (address|R/W) combination or a data byte over I2C
for (i=0;i<8;i++) {
i2cReceiveByte(1);
bytes[i] = i2cGetReceivedByte();
i2cSendStop();      //Send I2C stop condition in Master mode
for (i=0;i<8;i++) {
rprintf("%d.",bytes[i]);
Title: Re: Axon I2C Interface with DS1307 Real Time Clock
Post by: Admin on August 28, 2009, 11:38:17 AM
You have two Axons, use the other with SoR Scope ;D
Anyway, you forgot to state the problem :P
Post by: airman00 on August 28, 2009, 12:50:41 PM
Problem is that I keep getting only 0s.
My other Axon is unavailable right now ( embedded in another project I dont want to take apart)
Post by: Admin on August 28, 2009, 01:02:42 PM
Looking at the datasheet, I see this:
32.768kHz Crystal Connection
ICCA – SCL clocking at max frequency = 100kHz
and in your code I see this:
Is that right? (I only quickly glanced at everything) Perhaps bringing it to 10kHz is better?
Does your I2C code work for your other hardware?
Put your multimeter at frequency and look for something when a transaction should occur.
Post by: airman00 on August 28, 2009, 01:40:20 PM
Some slight progress. I brought it down to 2khz.  This is my first time playing with I2C.
I changed my code to this:
#define TARGET_ADDR   0x68
int bytes[7];
int i;
int buffer;
i2cSetBitrate(1);  //set I2C transaction bit rate to 100 kHz
buffer = 0;
i2cMasterSend(TARGET_ADDR, 0x01, &buffer);
i2cMasterReceive(TARGET_ADDR, 8, &bytes[0]);
for (i=0;i<8;i++) {
rprintfu08(bytes[i]);
rprintfChar('.');
rprintf("\r");
delay_ms(1500);
And now I get this out USB. The data remains the same, doesn't refresh.
00.00.00.00.01.00.1C.00.
In the datasheet is says that you have to enable the oscillator which is Bit 7 on register 0x00. I think I am enabling it when I do this:
buffer = 0;
Many thanks in advance
Post by: Admin on August 28, 2009, 01:53:26 PM
I almost feel like your buffer is way too small.
Try changing
int buffer;
to
#DEFINE BUFFER 0x50
Look at how I did my compass code:
http://www.societyofrobots.com/robotforum/index.php?topic=8393.0
But to be honest, I don't really understand I2C myself so hopefully someone else can chime in!
Post by: airman00 on August 28, 2009, 03:06:20 PM
From what I understand, your compass code sends a command through I2C and is replied to with 6 bytes. In my case I'm not sending a command at all, rather I'm trying to read one of the registers on the DS1307.
Post by: airman00 on August 29, 2009, 06:53:15 PM
Update:
I put on some code that (I think) sends out a I2C byte and checks for ACK . It also should read the values of 6 registers. My sending code checks out because I get the confirming messages out through UART. But my receiving code is just returning 0s.
Output from UART:
STA-SLA+W-DATA-STO 0= 0  1= 0  2= 0  3= 0  4= 0  5= 0
My code:
void i2cMasterSendDiag(u08 deviceAddr, u08 length, u08* data)
// this function is equivalent to the i2cMasterSendNI() in the I2C library
// except it will print information about transmission progress to the terminal
// disable TWI interrupt
cbi(TWCR, TWIE);
// send start condition
i2cSendStart();
i2cWaitForComplete();
rprintf("STA-");
// send device address with write
i2cSendByte( deviceAddr&0xFE );
rprintf("SLA+W-");
// send data
while(length)
i2cSendByte( *data++ );
rprintf("DATA-");
length--;
// transmit stop condition
// leave with TWEA on for slave receiving
i2cSendStop();
while( !(inb(TWCR) & BV(TWSTO)) );
rprintf("STO");
// enable TWI interrupt
sbi(TWCR, TWIE);
void control(void) {
int bytes[7];
int i;
int temp;
u08 in[6];  //6 bytes = MSB heading, LSB heading, MSB pitch, LSB pitch, MSB roll, LSB roll
int buffer;
i2cSetBitrate(5);  //set I2C transaction bit rate to 5 kHz
i2cMasterSendDiag(0x68,0x01,0x00);
delay_ms(10);
i2cMasterReceive(0x68, 6, &in[0]);  //read 6 byte data from slave to master
for (i=0;i<6;i++) {
rprintf("%d= %d  ",i,in[i]);
delay_ms(1500);
Post by: airman00 on August 29, 2009, 09:51:31 PM
Semi-success:
It seems like I'm getting I2C data now, but it doesnt look like the clock is starting. In the datasheet it says to write a 0 to bit 7 of register 0x00 to start the clock. I think I'm doing that , but the clock isnt starting. What is interesting as well is that Byte 0 returns 104 all the time - 104 being the decimal equivalent of the I2C Slave's address( 0x68 to hex is 104).
Any ideas?
I always get this out UART, it doesnt update
START   ADDR   REGISTER     DATA     STOP   SENT!!
START   ADDR   REGISTER  START      ADDR    STOP
0 = 104  1 = 209  2 = 162  3 = 69  4 = 69  5 = 139  6 = 22  7 = 45
Using this code:
delay_ms(10);
cbi(TWCR, TWIE);
// START
rprintf("START");
// I2C ADDRESS OF SLAVE
i2cSendByte(TARGET_ADDR&0xFE);    //Send (address|R/W) combination or a data byte over I2C
rprintf("   ADDR");
// I2C DEVICE REGISTER
rprintf("   REGISTER  ");
// DATA BYTE
i2cSendByte(0x00);
rprintf("   DATA  ");
// STOP
rprintf("   STOP  ");
rprintf(" SENT!!    ");
delay_ms(10);
while(1) {
// START
rprintf("\rSTART");
// I2C SLAVE ADRESS
rprintf("   ADDR");
// REGISTER
// START
rprintf("START   ");
// I2C SLAVE ADDRESS
i2cSendByte(TARGET_ADDR&0xFF);    //Send (address|R/W) combination or a data byte over I2C
rprintf("   ADDR    ");
// DATA BYTES
for (i=0;i<8;i++) {
i2cReceiveByte(1);
// STOP
rprintf("STOP\r");
for (i=0;i<8;i++) {
rprintf("%d = %d  ",i,bytes[i]);
delay_ms(1500);
Post by: airman00 on August 29, 2009, 10:00:35 PM
To make things wierder, when I change the frequency , I get different readings. But notice how the numbers are pretty much the same, just in a different order. Interestingly Byte 0 always remains 104 ( decimal value of the I2C slave's address)
2khz : 0 = 104  1 = 162  2 = 69  3 = 22  4 = 90  5 = 180  6 = 104  7 = 162
5 khz:  0 = 104  1 = 209  2 = 162  3 = 69  4 = 69  5 = 139  6 = 22  7 = 45
10 khz :  0 = 104  1 = 162  2 = 69  3 = 22  4 = 90  5 = 180  6 = 104  7 = 162
100khz :  0 = 104  1 = 209  2 = 209  3 = 162  4 = 69  5 = 69  6 = 139  7 = 22
Post by: Admin on August 30, 2009, 07:37:16 AM
This could maybe be because its outputting data faster than you are reading it with UART. For example, your mcu spends time outputting it to USB while the chip is being ignored with the next set of data.
