Mechanics and Construction => Mechanics and Construction => Topic started by: icoms8 on October 12, 2009, 09:02:14 PM
What would be the best material to use on a robot arm? I'm using 4-5 hs-311 and 1-2 are on the gripper and 1 is the bottom that moves the whole arm if i have to change the bottom servo so it can move more i can but what kind should i get? The arm wont lift much mabye a few grams.
If you're going to use it for very light things Sintra (expanded PVC) would work great. It is very easy to work with, and at 6mm thick it has some decent strength too.
http://www.solarbotics.com/products/sin6mm/ (http://www.solarbotics.com/products/sin6mm/)
Just a suggestion of a personal preference of mine. :)
I've attempted a robot arm, and bear in mind, theres gonna be a lot of leverage on thoese small servos.
That made no sense to me?
Are you sure the 311's can take all that load? 2+ servos+the materials+the load?
look at this
Yeah, i get that... but leverage doesnt seem like the right word? thats what confused me...
if you want to try and explain it to me, do it over pm's, we dont want to flood this topic :)
The strongest and lightest! :P
(you need to choose the one best for your application - if we don't know any details, we can't help!)
read this:
http://www.societyofrobots.com/mechanics_statics.shtml (http://www.societyofrobots.com/mechanics_statics.shtml)
http://www.societyofrobots.com/robot_faq.shtml#robot_arm (http://www.societyofrobots.com/robot_faq.shtml#robot_arm)
look at this
dellagd, I think you meant 'torque', not force :P
(facepalm) yes!
So does the leverage thing still go? And isn't torque a measurement of force?
Torque is moment of a force, it's a measure of a force related to an axis (in this case the main output gear is the axis). While leverage is the action of a lever, or the mechanical advantage of a lever.
