Electronics => Electronics => Topic started by: ksquared on November 07, 2009, 10:34:35 PM
I bread boarded the circuit for the $50 dollar robot - minus the sensors - but it doesn't work. I've checked and rechecked the thing, but yes, it works. I was using the 6-pin deal. Is there any good way of seeing if that chip is fried? I was using the AVRISP mkII at my dad's recommendation (as had to order a bunch of stuff from digi-key anyway.) When I use AVR studio, it always says "connection failed."
Oh, and thanks.
Try this code:
http://www.societyofrobots.com/robotforum/index.php?topic=7836.0 (http://www.societyofrobots.com/robotforum/index.php?topic=7836.0)
And attach an LED to any output port. If the LED flashes you are good! (Assuming you are using mega168)
Just a note, check the orientation of your programmer. I personally have attached it backwards many times.
Would this circuit http://www.google.com/url?sa=t&source=web&ct=res&cd=1&ved=0CAcQFjAA&url=http%3A%2F%2Fwww.tuxgraphics.org%2Fcommon%2Fimages2%2Farticle09043%2Ftest-circuit-led.pdf&rct=j&q=Atmega8+test+circuit&ei=Xk4TS4moD9L-nQeFw4nDAw&usg=AFQjCNGvR-z_mqERrzuatTI9Ay7jxb_eFg (http://www.google.com/url?sa=t&source=web&ct=res&cd=1&ved=0CAcQFjAA&url=http%3A%2F%2Fwww.tuxgraphics.org%2Fcommon%2Fimages2%2Farticle09043%2Ftest-circuit-led.pdf&rct=j&q=Atmega8+test+circuit&ei=Xk4TS4moD9L-nQeFw4nDAw&usg=AFQjCNGvR-z_mqERrzuatTI9Ay7jxb_eFg) do it?
I use the Atmega8. Is that hex file compatible? If nothing else, I can periodically oscillate the output pins myself....
oh and Thanks a lot!
Previous Solution: Upgrade AVR studio. Yea free tech support.
