Electronics => Electronics => Topic started by: rollingrobot on November 22, 2009, 11:06:26 AM
My 5v regulator is going nuts with 9v battery plugged in and I think its because a bridge between GND and + via ceramic capacitor. My multimeter says there is 0 resistance between these two. I don't know what else to do. I tried resoldering and stuff. Maybe these two pics would help :x
(http://i48.tinypic.com/245j4ec.jpg)
(http://i45.tinypic.com/2ykdobd.jpg)
A little less solder would help - and more control with where it goes.
You probably created a solder bridge and judging from your photos, you really need to practise.
Desolder the entire circuit. Tin wire ends and pads. resolder with minimum amount of added solder.
Either the above or, trace around all the parts until you find where the bridge is... Otherwise soeren's option is all you have.
Isn't the 0.1uF capacitor the bridge? I just do not understand the purpose of the capacitor.
No, a capacitor should measure infinite ohms. It's purpose is to stabilize against noise transients.
Try reading through this Capacitor Tutorial (http://www.sentex.ca/~mec1995/gadgets/caps/caps.html)
