General Misc => Misc => Topic started by: ukesh on December 02, 2009, 09:20:35 AM
Title: sending data to axon through hyperterminal
Post by: ukesh on December 02, 2009, 09:20:35 AM
Hello!
I'm trying to send a data to the axon through hyper terminal (UART1). But it doesn't seem to work ??? But the code compiled without an error. Am i doing something wrong?
my code:
void control(void)
int temp;
rprintf("\n enter the data");
temp=uart1GetByte();//returns -1 if no data present
if (temp==1)//if data received
while(1)
servo(PORTE,4,1400);
delay_ms(20);
Title: Re: sending data to axon through hyperterminal
Post by: Admin on December 02, 2009, 10:51:34 AM
You have the while loop in the wrong spot. Do this:
void control(void)
int temp;
while(1)
delay_ms(20);
Post by: ukesh on December 02, 2009, 12:18:58 PM
Tried your code. But doesn't seem to work too. ???
Post by: Admin on December 02, 2009, 12:25:14 PM
Can you define 'doesn't seem to work'?
We can't help if you don't tell us any information :P
Post by: ukesh on December 02, 2009, 12:38:56 PM
We can't help if you don't tell us any information :PSure ;D
On the hyper terminal, i get enter the data statement. After that when i press 1, and press enter in my keyboard nothing happens. The program just seems to stop there?
Post by: Admin on December 02, 2009, 12:56:08 PM
How do you know nothing happens?
Add a line in your code to reply when it gets data:
void control(void)
int temp;
while(1)
if (temp==1)//if 1 received
rprintf("stuff received");
delay_ms(20);
Post by: ukesh on December 02, 2009, 11:13:06 PM
I think the data is not sent to the axon. It gets stuck at the same place of the program
Post by: Admin on December 02, 2009, 11:19:21 PM
Lets just use my code. Put this in the control() function and see if pushing r helps.
char temp;
while(1)
if (temp == 'r')//if data received
rprintf("stuff");
Post by: ukesh on December 03, 2009, 03:22:42 AM
It works ;) And when i try this code it doesnt.
void control(void)
int temp;
while(1)
rprintf(" entered no is 1");
If you dont mind, can you explain why the first code didnt work? you said i placed the while loop statement in the wrong place. In my first code, the axon gets input once and if that input is equal to 1, the servo runs for an infinite time. Am i understanding something wrong?
Post by: Admin on December 03, 2009, 08:06:02 AM
In your first code, you have an infinite while loop with the servo code in it. Your code would never exit that while loop to check for a new character.
Post by: waltr on December 03, 2009, 08:09:59 AM
That line is expecting a value of 1 or 0x01. That is an ASCII "Start of Header" or a 'Control A'. Is that the keys you pressed?
The code example that did work used
which is expecting the 'r' ASCII character.
Here is info on ASCII:
http://en.wikipedia.org/wiki/ASCII (http://en.wikipedia.org/wiki/ASCII)
edit: corrected the 'r' character.
Post by: chelmi on December 03, 2009, 09:34:10 AM
which is expecting a Carriage Return ASCII character.
'r' is the character r. '\r' is carriage return.
Chelmi.
Post by: ukesh on December 07, 2009, 11:00:49 AM
It now works guys. Thanks for pointing me about ASCII code :)
Post by: waltr on December 07, 2009, 03:04:01 PM
Woo Hoo, isn't it a great feeling.
