Electronics => Electronics => Topic started by: karmax on December 09, 2009, 07:39:29 AM
i have 5v output from my sensor by which i want to control 230 V ac .i want to switch off or switch on using that 5v .it takes 25ma current only.please help me regarding the same thanks in advance
The simplest and safest way is with a relay. This provides total isolation between your controller and the AC mains.
Yes, but use an SSR (Solid State Relay) with zero cross shift, then the noise will be the minimum possible and the sensor won't need further circuitry (as it would with a regular relay).
i have to control ac voltage but my controlling signal is dc.will relay works...
yes very well...
use a transistor as a switch to control the relay coil. Your 5 V DC can switch the transistor ON and OFF..
BEAMer
I just did a google image search and found this.
http://interactive.usc.edu/members/phoberman/relayCircuit.gif (http://interactive.usc.edu/members/phoberman/relayCircuit.gif)
This is what i am talking about
BEAMer
Also, a thyristor (triac) can turn on AC with a very small DC current source.
The only snag is that is stays on until the AC goes to zero and resets the device.
You might like that functionality, like a latch.
http://www.technologystudent.com/elec1/thyris1.htm (http://www.technologystudent.com/elec1/thyris1.htm)
Here is a discussion regarding isolating the 230 VAC from the 5v circuit by using an opto-thyristor:
http://forum.allaboutcircuits.com/showthread.php?t=24187 (http://forum.allaboutcircuits.com/showthread.php?t=24187)
Alternistors and snubberless triacs:
http://en.wikipedia.org/wiki/TRIAC (http://en.wikipedia.org/wiki/TRIAC)
A triac is two thyristors. And since it is used to switch AC, there is no observable latch effect: the current is null every half cycle.
I used a triac to control a light with a photoresistor, it's very easy to use.
Chelmi.
I had a hunch I had something mixed up there.
Thanks.
Here is a mechanical relay.
It does need 72 ma to trigger it at 5V.
So you would need a transistor circuit someone mentioned above.
http://dipmicro.com/store/JS1-5V (http://dipmicro.com/store/JS1-5V)
The Triacs can trigger directly on tiny currents.
With one of these (http://www.panasonic-electric-works.com/peweu/en/html/solid_state_relays.php), you'd only need a single resistor in between and you have total optical isolation.
SSRs are very cheap and easy to use (mine required no external circuitry)
http://razorconcepts.net/ssr.html (http://razorconcepts.net/ssr.html)
$7 shipped from ebay ;D
