General Misc => Misc => Topic started by: Razor Concepts on December 09, 2009, 02:24:55 PM
Title: Air drop deployed robot
Post by: Razor Concepts on December 09, 2009, 02:24:55 PM
Requirements:
Robot fits in 4" diameter tube
Drops from a height of 1000'
Must travel 10meters after landing on ground.
Ground is tall grass (6" high), along with other small obstacles.
Currently my idea is to use a single-track design. Like a tank, but there is only one tread. A parachute is used to slow the robot down, and once on the ground it releases the parachutes and chugs away with the single tread. Currently the problem with that design is that if it lands on its side, it will not work.
There has to be something to laterally stabilize it. I was thinking small poles stick out on the side, but is it possible that the grass will get caught on the poles and prevent the robot from moving?
Title: Re: Air drop deployed robot
Post by: z.s.tar.gz on December 09, 2009, 02:41:41 PM
Have the poles drop off too
Post by: chelmi on December 09, 2009, 02:53:52 PM
Crazy idea: inflate a balloon that will push the robot back on it's track. once the balloon reaches a given size it will hit a small pin and pop.
Maybe you can use a CO2 cartridge and an electrical valve?
Post by: Razor Concepts on December 09, 2009, 04:16:58 PM
Thanks for the ideas! So the dropping poles/balloon thing may work to get it oriented to begin with, however once the robot gets going it may tip over.... hmmm....
Now thinking of that, maybe the poles can retract and extend whenever. I have an accelerometer mounted inside the robot, so that it could detect when it is tipped over or not. That could work I guess, but may be getting overly-complicated.
Post by: z.s.tar.gz on December 09, 2009, 04:47:27 PM
The poles can be at an angle so that the grass just gets pushed out of the way!
That way they don't even need to pop off!
Post by: cooldog on December 09, 2009, 06:21:35 PM
ur going to want to put suspension on the robot to sustain some of the shock depending on how the tall grass and parachute work to slow it down.
Post by: madsci1016 on December 09, 2009, 10:18:57 PM
I work for the Navy, coworkers had to  build a rover that is deployed from an AUV.
They used a design similar to this
http://www.lynxmotion.com/Category.aspx?CategoryID=111 (http://www.lynxmotion.com/Category.aspx?CategoryID=111)
Where the tires where bigger then the height of the robot, so it could land upside or rightside and still be able to travel.
They used rugged car window motors that seemed to hold up to being dropped.
Not sure if you could scale that down to fit in a 4" tube but hope it gives you some ideas.
Post by: Razor Concepts on December 09, 2009, 10:38:24 PM
Aha that reminded me of this Army robot:
http://www.recon-scout.com/graphics/rcspec_photo.jpg (http://www.recon-scout.com/graphics/rcspec_photo.jpg)
I think that may be the best design because it is so simple and already tube shaped!
Post by: madsci1016 on December 09, 2009, 10:45:30 PM
Looks perfect to me.  Glad i was able to jog your memory.
Post by: Asellith on December 10, 2009, 12:31:06 PM
Another idea have small triangles come out of the sides. curve the front end to prevent getting caught on anything. The angle can be very sharp just something to give it an unstable platform to potentially land on. Or better idea make it a curve that prevents the point from sticking into the ground. (another potential problem with the poles.) If you hit with sufficient force to bury them in the ground it may be hard to release them.
Post by: T0110100101101101K on December 14, 2009, 09:00:31 PM
If you really want a challenge, the link below shows a serpentine type of robotics that could possibly fit your specifications...and work like a snake in the grass ;D
http://www.cs.cmu.edu/~biorobotics/serpentine/serpentine.html (http://www.cs.cmu.edu/~biorobotics/serpentine/serpentine.html)
This guy should join SoR! ;)
