Software => Software => Topic started by: MasterRyko on July 23, 2007, 09:46:46 AM
Title: code for my robot
Post by: MasterRyko on July 23, 2007, 09:46:46 AM
I need some advice/help with my coding for my ATMEGA8 PIC.  I am building a robot using photoresistors and and 2 seperate motor drivers for a front and rear motor.  My front motor is a servo, which is being controlled by a H-Bridge.
We want the robot to stop when it gets too close to the light source, and to follow the light source by turning when needed.
(I have looked at the code for the photoresistor on the site and this is what i have extracted for my robot)
#include <avr/io.h>
#include "SoR_Utils.h"
int main(void)
   int sensor_left=0;//left photoresistor
   int sensor_right=0;//right photoresistor
   int threshold=4;//the larger this number, the more likely your robot will drive straight
configure_ports(); // configure which ports are analog, digital, etc.
   a2dInit(); // initialize analog to digital converter (ADC)
   a2dSetPrescaler(ADC_PRESCALE_DIV32); // configure ADC scaling
   a2dSetReference(ADC_REFERENCE_AVCC); // configure ADC reference voltage
while(1)
sensor_left=a2dConvert8bit(5);
sensor_right=a2dConvert8bit(4);
if(sensor_left > sensor_right && (sensor_left - sensor_right) > threshold)
         PORTD |=1<<PD2;
         PORTD &= !(1<<PD1);
         PORTD |=1<<PD4;
      else if(sensor_right > sensor_left && (sensor_right - sensor_left) > threshold)
         PORTD &=!(1<<PD0);
         PORTD |=1<<PD3;
         PORTD |=1<<PD4;
if(sensor_left > threshold)
PORTD &= !(1<<PD4);
else if(sensor_right > threshold)
PORTD &= !(1<<PD4);
return 0;
Im getting the following errors...
../TEST4/Code.c:13: undefined reference to `a2dInit'
../TEST4/Code.c:14: undefined reference to `a2dSetPrescaler'
../TEST4/Code.c:15: undefined reference to `a2dSetReference'
../TEST4/Code.c:20: undefined reference to `a2dConvert8bit'
../TEST4/Code.c:21: undefined reference to `a2dConvert8bit'
Title: Re: code for my robot
Post by: DomoArigato on July 23, 2007, 05:27:13 PM
I haven't used the SoR code before, but what that error message is saying is that it can't find the functions it listed.  Check to make sure the a2d.h file has been included and you have added a2d.c to your project or makefile.  Hope that helps.
Post by: Admin on July 23, 2007, 06:08:05 PM
In addition to what DomoArigato said, your makefile must also include ad2.h and ad2.c
(look at my makefile to see how I did it)
Post by: MasterRyko on July 27, 2007, 08:51:05 AM
Hi, i used your makefile and made the necessary changes (changed the name of the file) and im getting the following error:
make: *** No rule to make target `Code.elf', needed by `elf'.  Stop.
Any help on this would be awesome, thanks.
# Hey Emacs, this is a -*- makefile -*-
# WinAVR Sample makefile written by Eric B. Weddington, J?rg Wunsch, et al.
# Released to the Public Domain
# Please read the make user manual!
# Additional material for this makefile was submitted by:
#  Tim Henigan
#  Peter Fleury
#  Reiner Patommel
#  Sander Pool
#  Frederik Rouleau
#  Markus Pfaff
# On command line:
# make all = Make software.
# make clean = Clean out built project files.
# make coff = Convert ELF to AVR COFF (for use with AVR Studio 3.x or VMLAB).
# make extcoff = Convert ELF to AVR Extended COFF (for use with AVR Studio
#                4.07 or greater).
# make program = Download the hex file to the device, using avrdude.  Please
#                customize the avrdude settings below first!
# make filename.s = Just compile filename.c into the assembler code only
# To rebuild project do "make clean" then "make all".
# MCU name
MCU = atmega8
# Processor frequency.
#     This will define a symbol, F_CPU, in all source code files equal to the
#     processor frequency. You can then use this symbol in your source code to
#     calculate timings. Do NOT tack on a 'UL' at the end, this will be done
#     automatically to create a 32-bit value in your source code.
#     Typical values are:
#         F_CPU =  1000000
#         F_CPU =  1843200
#         F_CPU =  2000000
#         F_CPU =  3686400
#         F_CPU =  4000000
#         F_CPU =  7372800
#         F_CPU =  8000000
#         F_CPU = 11059200
#         F_CPU = 14745600
#         F_CPU = 16000000
#         F_CPU = 18432000
#         F_CPU = 20000000
F_CPU = 3686400
# Output format. (can be srec, ihex, binary)
FORMAT = ihex
# Target file name (without extension).
TARGET = Code
# List C source files here. (C dependencies are automatically generated.)
SRC = $(TARGET).c a2d.c
#SRC = $(TARGET).c timer.c uart.c buffer.c rprintf.c
# List Assembler source files here.
# Make them always end in a capital .S.  Files ending in a lowercase .s
# will not be considered source files but generated files (assembler
# output from the compiler), and will be deleted upon "make clean"!
# Even though the DOS/Win* filesystem matches both .s and .S the same,
# it will preserve the spelling of the filenames, and gcc itself does
# care about how the name is spelled on its command-line.
ASRC =
# Optimization level, can be [0, 1, 2, 3, s].
# 0 = turn off optimization. s = optimize for size.
# (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
OPT = 0
# Debugging format.
# Native formats for AVR-GCC's -g are stabs [default], or dwarf-2.
# AVR (extended) COFF requires stabs, plus an avr-objcopy run.
DEBUG = stabs
# List any extra directories to look for include files here.
#     Each directory must be seperated by a space.
EXTRAINCDIRS =
# Compiler flag to set the C Standard level.
# c89   - "ANSI" C
# gnu89 - c89 plus GCC extensions
# c99   - ISO C99 standard (not yet fully implemented)
# gnu99 - c99 plus GCC extensions
CSTANDARD = -std=gnu99
# Place -D or -U options here
CDEFS =
# Place -I options here
CINCS =
# Compiler flags.
#  -g*:          generate debugging information
#  -O*:          optimization level
#  -f...:        tuning, see GCC manual and avr-libc documentation
#  -Wall...:     warning level
#  -Wa,...:      tell GCC to pass this to the assembler.
#    -adhlns...: create assembler listing
CFLAGS = -g$(DEBUG)
CFLAGS += $(CDEFS) $(CINCS)
CFLAGS += -O$(OPT)
CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
CFLAGS += -Wall -Wstrict-prototypes
CFLAGS += -Wa,-adhlns=$(<:.c=.lst)
CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
CFLAGS += $(CSTANDARD)
# Assembler flags.
#  -ahlms:    create listing
#  -gstabs:   have the assembler create line number information; note that
#             for use in COFF files, additional information about filenames
#             and function names needs to be present in the assembler source
#             files -- see avr-libc docs [FIXME: not yet described there]
ASFLAGS = -Wa,-adhlns=$(<:.S=.lst),-gstabs
#Additional libraries.
# Minimalistic printf version
PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
# Floating point printf version (requires MATH_LIB = -lm below)
PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
PRINTF_LIB =
# Minimalistic scanf version
SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
# Floating point + %[ scanf version (requires MATH_LIB = -lm below)
SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
SCANF_LIB =
MATH_LIB = -lm
# External memory options
# 64 KB of external RAM, starting after internal RAM (ATmega128!),
# used for variables (.data/.bss) and heap (malloc()).
#EXTMEMOPTS = -Wl,-Tdata=0x801100,--defsym=__heap_end=0x80ffff
# only used for heap (malloc()).
#EXTMEMOPTS = -Wl,--defsym=__heap_start=0x801100,--defsym=__heap_end=0x80ffff
EXTMEMOPTS =
# Linker flags.
#  -Wl,...:     tell GCC to pass this to linker.
#    -Map:      create map file
#    --cref:    add cross reference to  map file
LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
LDFLAGS += $(EXTMEMOPTS)
LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
# Programming support using avrdude. Settings and variables.
# Programming hardware: alf avr910 avrisp bascom bsd
# dt006 pavr picoweb pony-stk200 sp12 stk200 stk500
# Type: avrdude -c ?
# to get a full listing.
AVRDUDE_PROGRAMMER = avrisp
# com1 = serial port. Use lpt1 to connect to parallel port.
AVRDUDE_PORT = com1    # programmer connected to serial device
AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
#AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
# Uncomment the following if you want avrdude's erase cycle counter.
# Note that this counter needs to be initialized first using -Yn,
# see avrdude manual.
#AVRDUDE_ERASE_COUNTER = -y
# Uncomment the following if you do /not/ wish a verification to be
# performed after programming the device.
#AVRDUDE_NO_VERIFY = -V
# Increase verbosity level.  Please use this when submitting bug
# reports about avrdude. See <http://savannah.nongnu.org/projects/avrdude>
# to submit bug reports.
#AVRDUDE_VERBOSE = -v -v
AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
# Define directories, if needed.
DIRAVR = c:/winavr
DIRAVRBIN = $(DIRAVR)/bin
DIRAVRUTILS = $(DIRAVR)/utils/bin
DIRINC = .
DIRLIB = $(DIRAVR)/avr/lib
# Define programs and commands.
SHELL = sh
CC = avr-gcc
OBJCOPY = avr-objcopy
OBJDUMP = avr-objdump
SIZE = avr-size
NM = avr-nm
AVRDUDE = avrdude
REMOVE = rm -f
COPY = cp
# Define Messages
# English
MSG_ERRORS_NONE = Errors: none
MSG_BEGIN = -------- begin --------
MSG_END = --------  end  --------
MSG_SIZE_BEFORE = Size before:
MSG_SIZE_AFTER = Size after:
MSG_COFF = Converting to AVR COFF:
MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
MSG_FLASH = Creating load file for Flash:
MSG_EEPROM = Creating load file for EEPROM:
MSG_EXTENDED_LISTING = Creating Extended Listing:
MSG_SYMBOL_TABLE = Creating Symbol Table:
MSG_LINKING = Linking:
MSG_COMPILING = Compiling:
MSG_ASSEMBLING = Assembling:
MSG_CLEANING = Cleaning project:
# Define all object files.
OBJ = $(SRC:.c=.o) $(ASRC:.S=.o)
# Define all listing files.
LST = $(ASRC:.S=.lst) $(SRC:.c=.lst)
# Compiler flags to generate dependency files.
GENDEPFLAGS = -Wp,-M,-MP,-MT,$(*F).o,-MF,.dep/$(@F).d
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
# Default target.
all: begin gccversion sizebefore build sizeafter finished end
build: elf hex eep lss sym
elf: $(TARGET).elf
hex: $(TARGET).hex
eep: $(TARGET).eep
lss: $(TARGET).lss
sym: $(TARGET).sym
# Eye candy.
# AVR Studio 3.x does not check make's exit code but relies on
# the following magic strings to be generated by the compile job.
begin:
   @echo
   @echo $(MSG_BEGIN)
finished:
   @echo $(MSG_ERRORS_NONE)
end:
   @echo $(MSG_END)
   @echo
# Display size of file.
HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
ELFSIZE = $(SIZE) -A $(TARGET).elf
sizebefore:
   @if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); echo; fi
sizeafter:
   @if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); echo; fi
# Display compiler version information.
gccversion :
   @$(CC) --version
# Program the device.
program: $(TARGET).hex $(TARGET).eep
   $(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
# Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
COFFCONVERT=$(OBJCOPY) --debugging \
--change-section-address .data-0x800000 \
--change-section-address .bss-0x800000 \
--change-section-address .noinit-0x800000 \
--change-section-address .eeprom-0x810000
coff: $(TARGET).elf
   @echo
   @echo $(MSG_COFF) $(TARGET).cof
   $(COFFCONVERT) -O coff-avr $< $(TARGET).cof
extcoff: $(TARGET).elf
   @echo
   @echo $(MSG_EXTENDED_COFF) $(TARGET).cof
   $(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
# Create final output files (.hex, .eep) from ELF output file.
%.hex: %.elf
   @echo
   @echo $(MSG_FLASH) [email protected]
   $(OBJCOPY) -O $(FORMAT) -R .eeprom $< [email protected]
%.eep: %.elf
   @echo
   @echo $(MSG_EEPROM) [email protected]
   -$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
   --change-section-lma .eeprom=0 -O $(FORMAT) $< [email protected]
# Create extended listing file from ELF output file.
%.lss: %.elf
   @echo
   @echo $(MSG_EXTENDED_LISTING) [email protected]
   $(OBJDUMP) -h -S $< > [email protected]
# Create a symbol table from ELF output file.
%.sym: %.elf
   @echo
   @echo $(MSG_SYMBOL_TABLE) [email protected]
   $(NM) -n $< > [email protected]
# Link: create ELF output file from object files.
.SECONDARY : $(TARGET).elf
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
   @echo
   @echo $(MSG_LINKING) [email protected]
   $(CC) $(ALL_CFLAGS) $(OBJ) --output [email protected] $(LDFLAGS)
# Compile: create object files from C source files.
%.o : %.c
   @echo
   @echo $(MSG_COMPILING) $<
   $(CC) -c $(ALL_CFLAGS) $< -o [email protected]
# Compile: create assembler files from C source files.
%.s : %.c
   $(CC) -S $(ALL_CFLAGS) $< -o [email protected]
# Assemble: create object files from assembler source files.
%.o : %.S
   @echo
   @echo $(MSG_ASSEMBLING) $<
   $(CC) -c $(ALL_ASFLAGS) $< -o [email protected]
# Target: clean project.
clean: begin clean_list finished end
clean_list :
   @echo
   @echo $(MSG_CLEANING)
   $(REMOVE) $(TARGET).hex
   $(REMOVE) $(TARGET).eep
   $(REMOVE) $(TARGET).obj
   $(REMOVE) $(TARGET).cof
   $(REMOVE) $(TARGET).elf
   $(REMOVE) $(TARGET).map
   $(REMOVE) $(TARGET).a90
   $(REMOVE) $(TARGET).sym
   $(REMOVE) $(TARGET).lnk
   $(REMOVE) $(TARGET).lss
   $(REMOVE) $(OBJ)
   $(REMOVE) $(LST)
   $(REMOVE) $(SRC:.c=.s)
   $(REMOVE) $(SRC:.c=.d)
   $(REMOVE) .dep/*
# Include the dependency files.
-include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
# Listing of phony targets.
.PHONY : all begin finish end sizebefore sizeafter gccversion \
build elf hex eep lss sym coff extcoff \
clean clean_list program
Post by: MasterRyko on July 27, 2007, 09:07:50 AM
I resolved the problem, was due to a missing file.  Thanks!
