Author Topic: Getting the limiting pin in the servo.  (Read 2985 times)
Offline HellboyTopic starter
« on: July 10, 2010, 04:14:35 AM »
I wanted to modify the servo for 360 rotation.
The gears in the servo are metal servo and there is a small metal pin in the main gear.
Is there anyway of getting it out?
Offline Joker94
  • Helpful? 26
Re: Getting the limiting pin in the servo.
« Reply #1 on: July 10, 2010, 04:26:43 AM »
generally the pin is not fixed, it is just there with a tight fit.
I have never seen a metal gear servo with a fixed pin.
if it is fixed the next thing is to grind it out with a file, or even better a tool like a dremel. take any means necessary to remove the mechanical stop without damaging the gear.
