Don't ad-block us - support your favorite websites. We have safe, unobstrusive, robotics related ads that you actually want to see - see here for more.
generates a current between 0-100 millivolts
Hmmmmm thats not a link to a datasheet, and I'm not signing up for an account with them
Hmmmmm thats not a link to a datasheet, and I'm not signing up for an account with them Quotegenerates a current between 0-100 millivoltsA voltage or a current? If voltage, then yes, you should use an op-amp. Op-amps tend to not be so accurate after around 20x amplification, so check the datasheets. You can always use more than one op-amp in series.I recommend just powering up the sensor and using a voltage meter first to see what voltages you get, that way you'll know better of what kind of amplification you'd need.
[...] Op-amps tend to not be so accurate after around 20x amplification, so check the datasheets.
codiak <- According to several divers sites, this particular sensor has an output stated as +/-10mV, not the 0..100mV stated by you.Not sure of the +/-part though, but perhaps it can detect antimatter, or at least anti-oxygen
If it is for anything health-critical, I'd advice against homemade gizmos lacking Quality Assurance!
Meters using these sensors need to be recalibrated with a known/trusted air supply prior to use.
I'll be sure the lawyers are the first users... ;-)For my purposes it's not in the critical loop
