Author Topic: Temperature Alarm  (Read 4843 times)
Offline mdaislTopic starter
Temperature Alarm
« on: January 25, 2011, 11:36:00 AM »
I have never built anything electronic before, but after glancing at the tutorials, i would very much like to build a temperature alarm with an adjustable set point. If temp. drops below set point, an alarm goes off. If i can accomplish this, would like to take it one step further. If temp. drops below set point, an alarm goes off and makes a telephone call to pre determined number. Any help getting started would be greatly appreciated, thanks.
« Last Edit: January 25, 2011, 11:37:22 AM by mdaisl »
Re: Temperature Alarm
« Reply #1 on: January 25, 2011, 12:17:06 PM »
The first part is rather easy. A temperature sensor and a voltage comparator is all that is needed.
There are a number of different devices that can sense temperature. A Thermistor (temperature varying resistor) are cheap and easy to use. They don't have a linear response to temperature changes but that wouldn't be a problem.
The LM339 is a commonly available voltage comparator (there are others). One input is the reference voltage that is set from a pot (potentiometer) and the output go high or low depending on whither the input voltage is higher or lower than the reference voltage.
Search on the parts I mentioned for more info on how to use them. This is a good starting project.
The second part can be done but it isn't some thing I've done so other will need to help you.
« Reply #2 on: January 27, 2011, 10:33:45 AM »
As waltr mentioned, this is quite easy.
What kind of alarm did you have in mind?
Is it just for fun, or do you have a need for it?
A bit more work. Either consider using an old cell phone with a prepaid card (then it's fairly easy), or, if the application allows it, perhaps a cheap radio module could be used instead.
Offline Fr0stAngel
  • [O_O] what??
« Reply #3 on: February 01, 2011, 12:39:25 AM »
Try using
- LM335 [directly calibrated in kelvins]
- LM35 [calibrated in centigrades]
after this, you can either feed its output to an ADC(analog-to-digital converter) or use a voltage comparator like LM324N to obtain your output with a set point voltage
'crazy' is the new hype! =)
« Reply #4 on: February 01, 2011, 03:00:52 PM »
Try using
That would be gross overkill, especially in the light of this being a first time project. An NTC is all it takes, no calibration is needed.
KISS
Offline galannthegreat
« Reply #5 on: February 01, 2011, 10:13:18 PM »
I find using LM335s pretty easy to use myself, might not be the same for everybody, but I did do something like this for an arduino, and it worked pretty nicely.
http://www.societyofrobots.com/robotforum/index.php?topic=12196.0
Kurt
Offline Fr0stAngel
  • [O_O] what??
« Reply #6 on: February 01, 2011, 11:12:51 PM »
I'm sorry, i think i may have mis conveyed the message....they come 'pre-calibrated'... meaning the voltage change is directly proportional to  the change in temperature in kelvins/centigrades.
and their response is fairly linear over a good range of temperature. yet you still may need the ambient temperature to calculate the error and subtract/add from the original value though...so maybe you are right , sir, for a beginner it may pose issues.  :D
« Reply #7 on: February 02, 2011, 07:08:28 PM »
Don't get me wrong, I know they're both precise, calibrated and comparatively simple to use when you've got a bit of experience (I've been in this game for a wee bit of time and I used my first LM35 around the early eighties IIRC).
But... a thermostat doesn't need absolute temp readings and besides, the OP clearly states that this is his(/her?) first project and an NTC is beyond any doubt the easier one to both use and understand.
Starting simple there's a chance to comprehend the stuff and thus learn. Starting just a shade to complicated, there's a real chance of failure and quitting the hobby.
Offline Fr0stAngel
  • [O_O] what??
« Reply #8 on: February 03, 2011, 03:48:07 AM »
+1 , sir i agree. :D
Offline offencerobotics
