Squirrels have fuzzy tails.
You could increase the wheel size.
I've taken the PWM frequency down to 500Hz and gotten a little more torque and lower stall speed,
but I still have no ability to go slow. Aside from modifying the gearbox to get a better ratio, is there anything else I could try?
when you controle the motor are you doing so through the built in chip on the platform or are you useing a motor driver/ h-bridge?
If you feed it say 1% duty cycle PWM (eg. at the 500Hz) it doesn't go slow?
You could try adding wheel encoders to the equation. increase duty cycle 'till it moves and reduce it if the encoder tells you you're above wanted speed.
Since it probably has got a single drive motor, you could most likely just mod it somewhere in the present gearbox, by changing a gear or two and it would be so much easier to get a good result that way.
I should have mentioned, I already have a wheel encoder. Duty cycle won't move the bot until it gets high enough, and then it goes fast.
I don't think that's going to be easy. Here's the gearbox:[snip photo]The Hi/Lo switch is on Lo to get the most torque (not that it makes much difference, I think that was added for "coolness"). And the gearbox is pretty compact. I'm not sure what I can modify, but I'll open it up for a look.
