Author Topic: Problems Compiling Files (Axon + Ubuntu)  (Read 3249 times)
Offline JdogTopic starter
« on: May 09, 2011, 09:01:48 PM »
Hi, I recently switched over to Ubuntu and am trying to get my Axon working. I followed this tutorial: http://www.societyofrobots.com/robotforum/index.php?topic=8216.0
I am able to load files that I have previously compiled on my windows perfectly.  I'm running into problems though when I try to edit those files and recompile them.  I ran into the same problem as Ryltar in http://www.societyofrobots.com/robotforum/index.php?topic=10792.0. and am now using his makefile which lets me run make.  But when I run it and then upload the new hex, the changes I've made to the software do not show up.
Here is the output when I run make:
turdferg@turdferg-desktop:~/Documents/Robotics/my_robots/Axon/helloWorldUbuntu$ make
-------- begin --------
avr-gcc (GCC) 4.3.4
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Size before:
avr-size: unrecognized option '--mcu=atmega640'
Usage: avr-size [option(s)] [file(s)]
 Displays the sizes of sections inside binary files
 If no input file(s) are specified, a.out is assumed
 The options are:
  -A|-B     --format={sysv|berkeley}  Select output style (default is berkeley)
  -o|-d|-x  --radix={8|10|16}         Display numbers in octal, decimal or hex
  -t        --totals                  Display the total sizes (Berkeley only)
            --common                  Display total size for *COM* syms
            --target=<bfdname>        Set the binary file format
            @<file>                   Read options from <file>
  -h        --help                    Display this information
  -v        --version                 Display the program's version
avr-size: supported targets: elf32-avr elf32-little elf32-big srec symbolsrec verilog tekhex binary ihex
Size after:
 The options are:
Errors: none
-------- end --------
Does anyone know why this is happening?  Any help is greatly appreciated  :)
Offline adanvasco
  • Helpful? 6
Re: Problems Compiling Files (Axon + Ubuntu)
« Reply #1 on: May 27, 2011, 09:12:53 PM »
Hi. Can you post the source code of the files you're using as well as the makefile?
In the meantime, take a look at this option:
http://www.societyofrobots.com/robotforum/index.php?topic=13796.0
Knowledge does not weigh.
« Reply #2 on: May 31, 2011, 06:17:51 PM »
This may or may not be a problem, but sometimes I have this problem when I'm a bit sleepy . . .
Check the creation time/date of your .hex file to make sure you are uploading the most recently compiled .hex. Sometimes I upload another .hex with the same file name and get really confused for 20+ minutes . . .
