Author Topic: switch  (Read 13465 times)
Offline ruddock1234Topic starter
switch
« on: March 21, 2015, 01:26:44 PM »
How do I add a switch to this circuit to turn battery on and off
Offline Ibaeni
Re: switch
« Reply #1 on: March 21, 2015, 02:17:27 PM »
You could simply put one in series with the positive lead of the battery. A simple SPST switch would do the trick.
Re: switch
« Reply #2 on: March 21, 2015, 03:48:32 PM »
So it doesn't have to be connected to ground
Offline Ibaeni
Re: switch
« Reply #3 on: March 22, 2015, 10:51:52 AM »
No it does not. Essentially what a really basic switch does is disconnect and reconnect the wire. I'll put a link to an example switch below. Basically what is happening is that when you switch it on, the wire is reconnected and when it is flipped off the wire is disconnected.
This link has a good picture of how to turn a light on and off with a switch. It is the same idea with your circuit, except instead of a light, it is a more complicated circuit.
http://www.homelightingtips.org/light-control-systems/light-switch-diagram/
Below is a link to an example switch from sparkfun.
https://www.sparkfun.com/products/9276
