Author Topic: ohmic current sensors - still being sold?  (Read 13798 times)
Offline AdminTopic starter
« on: May 04, 2015, 07:23:14 AM »
I'm looking for some smd ohmic current sensors, up to 10A, preferably soic 8 pin. Unfortunately my circuit has massive magnetic field noise so need the resistive type.
They were very common 10 years ago, but it seems the entire industry has moved to hall effect current sensors.
Anyone seen them being sold anywhere? I still see current sense resistors being sold, so someone must be need them . . .
Offline mklrobo
Re: ohmic current sensors - still being sold?
« Reply #1 on: May 04, 2015, 08:18:01 AM »
 ;D Hello!
I found that Mouser has the item you are looking for, up to 200 watts.
They sell it as basic 4 kelvin current sensor. By the name, I would assume
that the calculations are based on heat. They are very accurate.  :)
 This link has the PDF info that will help;
www.mouser.com/pdfDocs/Ohmite_CSResistors.pdf
Good luck!  ;D ;D ;D
Offline mklrobo
« Reply #2 on: May 04, 2015, 10:26:44 AM »
 :) Hello!
At this site;
http://www.ohmite.com
Has the item you are looking for. Select the current sensing part in the
web page, and it will take you to the various products they offer.  8)
« Reply #3 on: May 04, 2015, 11:17:03 AM »
It wasn't the resistors I needed, but the sensors . . .   :P
Anyway, I found them here:
http://www.digikey.com/product-search/en/integrated-circuits-ics/linear-amplifiers-instrumentation-op-amps-buffer-amps/2556125?stock=1
They were listed as op-amps and not as current sensors.
