Author Topic: need help with the $40 robot  (Read 6569 times)
Offline hate_forever143Topic starter
« on: February 13, 2008, 07:56:54 AM »
cut five 5 cm long wires and add molex connectors to each
are these molex connectors necessary..???
and how does the robot avoid obstacles and then detect the line again..???
Re: need help with the $40 robot
« Reply #1 on: March 02, 2008, 09:16:26 PM »
Connectors aren't really neccessary, but they make your wiring easier to modify and work with. You can just solder the wires in if you really want.
the rest is explained in the tutorial . . .
« Reply #2 on: March 02, 2008, 09:29:33 PM »
the robot does not detect obstacles AND go on the line
it does only one at a time
cannot do both
my robot can do both
Offline Pratheek
    • Probots
« Reply #3 on: March 03, 2008, 04:58:30 AM »
The $40 robot can do both obstacle avoiding(can avoid shadows cast by objects) and black line following at the same time.
To use the robot as a obstacle avoider and black line follower follow the method given at http://www.societyofrobots.com/member_tutorials/node/66
« Reply #4 on: March 03, 2008, 05:54:18 AM »
Really?
It can follow a line, avoid an obstacle on the line, and retake the line again?
Still very cool stuff.
Offline Mcrich113
« Reply #5 on: March 05, 2008, 12:05:51 AM »
How is this only $40s?There is so much stuff!
Offline Pratheek
    • Probots
« Reply #6 on: March 05, 2008, 12:53:21 AM »
The $40 robot does not use any microcontroller, which cuts down the cost of a programmer and the microcontroller itself.
Actually, the DC motors are the most expensive parts of the robot. More than half of the money is spent on the motors. So if you already have DC motors, you will only need another $20 to build the robot.
Offline Mcrich113
« Reply #7 on: March 05, 2008, 05:09:46 PM »
do u think u could make it even less expensive?
Offline Pratheek
    • Probots
« Reply #8 on: March 06, 2008, 05:05:49 AM »
Yes of course. I purchased all the parts from a local hobby shop and the whole robot costed around 600 Indian rupees, which is almost $15.
