Author Topic: ComparingSmallVoltages  (Read 2931 times)
Offline mpuvddTopic starter
« on: June 29, 2008, 10:03:31 PM »
Could anyone tell me how to compare small voltages (.354V vs. .454V) with a comparator, or how to boost them so that I can compare them?  Currently I'm using a lm339, but I can't get it to compare those low voltages, though in the datasheet, it says that the input offset voltage is +/- 2 mVdc.
Thanks a lot,
Seth Haddix
Any man who reads too much and uses his own brain too little falls into lazy habits of thinking-Einstein
Offline bens
Re: ComparingSmallVoltages
« Reply #1 on: June 29, 2008, 10:05:27 PM »
You could use an op amp.
« Reply #2 on: June 29, 2008, 10:06:43 PM »
What kind of configuration, I'm new to electronics, especially op amps?
Offline bens
« Reply #3 on: June 30, 2008, 12:23:59 AM »
By itself an op amp will amplify a voltage difference by maybe a factor of 1000, which usually means it will just go to the maximum or minimum supply voltage to the op amp.  By adding a feedback loop with some key resistors you can control the gain of the op amp to amplify the voltage difference by a factor of your choice.
Take a look at the non-inverting amplifier circuit on this page (you will probably want some variation of this):
http://ourworld.compuserve.com/homepages/Bill_Bowden/opamp.htm
You might also want to check out the wikipedia page on op amps:
http://en.wikipedia.org/wiki/Operational_amplifier
You could also consider purchasing a fixed-gain amplifier.  For example:
http://www.national.com/pf/LM/LMP8270.html
- Ben
Offline ALZ
« Reply #4 on: June 30, 2008, 02:26:59 AM »
What is the problem you are having? A .1 of a volt "compare small voltages (.354V vs. .454V) with a comparator" is more than enough for a comparator to work with. Are you sure it is not working? With a comparator you will only get a high or low voltage, there is no in between like with an op amp.
http://robotics.scienceontheweb.net
« Reply #5 on: June 30, 2008, 08:14:12 AM »
Exactly, I'm only trying to get a one or a zero, depending on which voltage is higher.
Is the comparator not fit for such small voltage?
« Reply #6 on: July 05, 2008, 08:50:57 PM »
It sounds like your circuit is wrong . . . whats your schematic look like?
Like I tell everyone, this should help:
http://www.societyofrobots.com/robot_faq.shtml#circuit_debug
