Author Topic: Recycling Robot  (Read 6941 times)
Offline fallenangelTopic starter
Recycling Robot
« on: September 12, 2008, 10:19:25 AM »
I have to build a robot that detects aluminum cans, plastic bottles and glass bottles. They are all Coke products. What would be the best way that a robot can detect these materials?
I was thinking a sensor might possibly do this. Using a scale to weight each item is another option. Maybe even a slight pressure applied on each container will be enough to differentiate between the three.
Any ideas would be greatly appreciated. Thanks.
Offline bulkhead
Re: Recycling Robot
« Reply #1 on: September 12, 2008, 03:20:28 PM »
Aluminum conducts electricity--you could have a claw grab it and see if it completes the circuit (like a push button).  Then reaction to pressure can be used to distinguish between plastic and glass.
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
    • Ro-Bot-X Designs
Re: Recycling Robot
« Reply #2 on: September 12, 2008, 07:12:25 PM »
By the size. Each container has a different diameter and lenght.
Re: Recycling Robot
« Reply #3 on: September 15, 2008, 02:56:42 PM »
Detect the materials (from a lack of anything)? Or detect which material is which? Or detect a Coke product from a non-Coke product?
Offline izua
    • izua electronics
Re: Recycling Robot
« Reply #4 on: September 15, 2008, 03:11:33 PM »
What about a can half-filled with coke, accidentally dropped? That might be bad for electronics.
Offline pomprocker
Re: Recycling Robot
« Reply #5 on: September 15, 2008, 04:30:40 PM »
id suppose a robot would need the same sensory that we have to detect it.
vision
Offline Jdog
Re: Recycling Robot
« Reply #6 on: February 13, 2009, 11:51:34 AM »
You could have a copper coil that all of the bottles pass. If the magnetic field changes, then it's an aluminum can. Then you can have the non-aluminum cans continue until they reach a certain point where an arm comes down with a pressure sensor on the end of it. You could program it so that if the pressure sensor gives a high pressure reading then it's glass, and if not it's plastic.
Offline Asellith
  • Helpful? 9
    • CorSec Engineering
Re: Recycling Robot
« Reply #7 on: February 13, 2009, 01:09:52 PM »
Place two prongs on a robotic arm. If the prongs penetrate the material and it conducts its a can. If it penetrates and does not conduct its plastic. If it does not penetrate its glass
Jonathan Bowen
CorSec Engineering
www.corseceng.com
