Author Topic: Sonar Question  (Read 2852 times)
Offline JoeSkullTopic starter
Sonar Question
« on: November 18, 2008, 04:08:04 PM »
OK so i haven't made a robot yet, but Ive been designing one and i was planning on using sonar.
so i was wondering which would be a good one to get, kinda cheap and lightweight(planning on 4).
also, does anyone have a program suited to a 4 way sensor??
and tell me if there is anything else I should know.
Come on, someone must have used sonar by now!
« Last Edit: November 18, 2008, 06:06:47 PM by JoeSkull »
Offline MaltiK
Re: Sonar Question
« Reply #1 on: November 18, 2008, 07:03:45 PM »
you can buy 4 separate transducers (cheaper less efficient)
or you can buy 4 sonars (more expensive, more efficient)
the SRF05 is my favorite, but many people prefer the Parallax PING))), they are all over the net just do a google search, as for the seperate transducers, they too are all over the net.
Warranty
Re: Sonar Question
« Reply #2 on: November 18, 2008, 07:29:26 PM »
Whats a tranducer, hows it different/better??
Offline MaltiK
Re: Sonar Question
« Reply #3 on: November 18, 2008, 07:36:34 PM »
srf05
transducers
actually im not sure if theyre called that but theyre a cheaper solution nonetheless
compare the specs:
SRF02 ("transducer" in my terms)
Range - 16cm to 6m.
Power - 5v, 4mA Typ.
Frequency - 40KHz.
Size - 24mm x 20mm x 17mm height.
Analogue Gain - Automatic 64 step gain control
Connection Modes
1 - Standard I2C Bus.
2 - Serial Bus - connects up to 16 devices to any uP or UART serial port
Full Automatic Tuning - No calibration, just power up and go
Timing - Fully timed echo, freeing host controller of task.
Units - Range reported in uS, mm or inches.
Light Weight - 4.6gm
SRF05
Range - 1cm to 4m.
Frequency - 40KHz.
Size - 43mm x 20mm x 17mm height.
Two operational modes are available, Single pin for trig/echo or 2 Pin SRF04 compatible.
The input Trigger is a 10uS Min. TTL level pulse
Echo Pulse is Positive TTL level signal, with the width proportional to the object range.
Warranty
Offline creedcradle
  • Physics Robotics
Re: Sonar Question
« Reply #4 on: November 18, 2008, 07:38:45 PM »
A transducer is a device that converts energy into sound waves above the normal range of human hearing. With proper signal conditioning thru a microcontroller or some sort of circuit, a digital output can be assigned as "low" or "high".
SONAR is also a transducer and uses the same principle but SONAR are frequently used in underwater navigation.
-creedcradle
LEARN TO SHARE and SHARE TO LEARN!
Offline pomprocker
Re: Sonar Question
« Reply #5 on: November 19, 2008, 11:59:22 AM »
The analog ones are very easy to interface with, but the digital one (parrallax ping) is very easy to come by (radio shack)
There is also a link to a tutorial in my signature on how to interface with the ping.
