Author Topic: Low error margin Sharp IR  (Read 2387 times)
Offline ArmouralisTopic starter
« on: January 08, 2009, 07:12:16 PM »
what would you consider acceptable error? if it is off by .4 inches, is that ok? or maybe .04 inches? there will always be some error
i have a sharp ir rangefinder  (GP2Y0A21YK), and i would like to know the margin of error in a average room of an average house on a wall
i would idealy like a sensor that has a 1/4 inch of an error.
is the GP2Y0A21YK acurate to 1/4 inch, or what is it accurat to?
is the sonar more accurate? or is another type of ir range finder more accurate?  what would their margin of error be?
thx in advance
i would like to know using the sharp ir range finder (GP2Y0A21YK) how close to three inches i would be thx
« Last Edit: January 08, 2009, 07:17:37 PM by Armouralis »
Re: Low error margin Sharp IR
« Reply #1 on: January 14, 2009, 11:24:03 AM »
It has non-linear accuracy, meaning that the accuracy improves the closer the object gets to the Sharp IR. 1/4th inch sounds reasonable.
Sonar is less accurate, and much slower. Check the sonar datasheet for error margin.
