Author Topic: Lipo battery  (Read 2753 times)
Offline karmaxTopic starter
Lipo battery
« on: February 19, 2009, 05:25:18 AM »
hi .. i have lipo battery which have 1 red wire and 2 black wire .. can you tell me whats the function of these three wires
Offline Qubix
Re: Lipo battery
« Reply #1 on: February 19, 2009, 06:25:31 AM »
hmmm... thats a strange one.
Usually red will be positive, black will be negative. Maybe there are just two negative wires (to prevent it being inserted with the wrong polarity perhaps). I guess the easiest way to find out would be with a multimeter, check the voltage between the different wires and check if the black wires are connected together.
Hope this helps  :)
David
http://robots.ie  - Ireland's robot site
    • RazorConcepts
Re: Lipo battery
« Reply #2 on: February 19, 2009, 06:56:24 AM »
If it's a two cell lipo, those 3 wires could be the balancing tap.
Offline TrickyNekro
  • Hardware and Firmware Designer
    • The Hellinic Robots Portal
Re: Lipo battery
« Reply #3 on: February 19, 2009, 11:42:41 AM »
the one black at the on side is ground...
the middle is the first cell so you must get a voltage round 3V and at the red you get around 6V to 7V
Re: Lipo battery
« Reply #4 on: March 01, 2009, 06:33:18 AM »
Whats the part number? How many cells? Voltage? brand name? Looked up the datasheet? What does your multimeter say? ;D
