Author Topic: Servo didn't come with mounting hardware?  (Read 4833 times)
Offline offyTopic starter
« on: March 09, 2009, 01:12:01 PM »
I bought the HS-311 servo's and it said it would come with mounting hardware. I looked and didn't find anything for use. Could someone tell me how to mount a servo _ and the screws needed to go this way | so it will attach to the chassis.
Offline superchiku
  • cooll
Re: Servo didn't come with mounting hardware?
« Reply #1 on: March 09, 2009, 02:03:18 PM »
the servo mut hve 2 holes one each side of the wheel...those can be used fr attaching
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Offline pomprocker
« Reply #2 on: March 09, 2009, 04:25:59 PM »
That is correct, the parts list does not mention mounting posts only mounting hardware:
When it says servo hardware it is referring to the eyelets grommets and screws.
http://www.servocity.com/html/servo_mounting_hardware.html
« Reply #3 on: March 09, 2009, 04:27:58 PM »
is there a way I can make it bed 90 degrees so I can attach it to the chassis.
Offline pomprocker
« Reply #4 on: March 09, 2009, 04:29:14 PM »
These are easy to attach to the bottom of your chassis
http://www.lynxmotion.com/Product.aspx?productID=286&CategoryID=87
Offline pomprocker
« Reply #5 on: March 09, 2009, 04:31:12 PM »
The easy way to do this is to bend an L out of a bracket of some sort
http://www.trossenrobotics.com/store/p/3333-E-Z-Aluminum-Servo-Bracket-Two-Pack.aspx?feed=Froogle
« Reply #6 on: March 09, 2009, 04:41:24 PM »
I will search my house for some old toy from when I was little to find some metal and bend it. Great idea. Thanks. *Searches for scrap metal*
