Author Topic: Smoke Sensor  (Read 3803 times)
Offline hendrachubbyTopic starter
    • My-Blog
Smoke Sensor
« on: June 19, 2009, 06:40:36 AM »
Anyone can recommend me a sensor to detect smoke intensity ?
Offline galannthegreat
Re: Smoke Sensor
« Reply #1 on: June 19, 2009, 11:35:11 AM »
If the idea of using a smoke detector is in your mind, don't do it, it has a radioactive element inside of it (Americium). Now my suggestion would be looking at optical methods, such as this http://en.wikipedia.org/wiki/Smoke_detector.
Hope this helps! ;D
Kurt
Re: Smoke Sensor
« Reply #2 on: June 19, 2009, 04:18:09 PM »
Hack a smoke alarm: Wire the buzzer pin to your microcontroller. Done. ;D
(or any other pin that does binary and not PWM, just use your multimeter to check)
    • My-Blog
Re: Smoke Sensor
« Reply #3 on: June 19, 2009, 04:26:46 PM »
can i use combination of photodiode and LED ?
Re: Smoke Sensor
« Reply #4 on: June 19, 2009, 04:57:39 PM »
tell us more about the environment, distance away, type of smoke, etc
Offline HDL_CinC_Dragon
Re: Smoke Sensor
« Reply #5 on: June 19, 2009, 09:48:01 PM »
Where there is smoke their is heat. What temperature range will your circuit be exposed to?
United States Marine Corps
Infantry
Returns to society: 2014JAN11
    • My-Blog
Re: Smoke Sensor
« Reply #6 on: June 20, 2009, 06:35:37 AM »
i want to measure cigarette smoke thickness, because i got a research about thermoforesist filter..so i must measure the smoke intensity before and after the filter...i've tried using combination of led and photodiode, but the voltage deviation is small...any idea ?
Offline awally88
Re: Smoke Sensor
« Reply #7 on: June 20, 2009, 07:01:32 AM »
Try using an Op Amp to amplify the voltage that you get from the photoresitor.
Re: Smoke Sensor
« Reply #8 on: June 20, 2009, 08:58:55 AM »
You could buy a cheap fire alarm (make sure it's got an optical detector - the package will tell, but they are the usual type sold cheap - $4 to $8 should get you one), it has got a matched pair of IR LED and IR photo diode that you can harvest and you'll see how it is mounted.
Here is one I dismantled to use the detector for automatic opening of windows on "poker nights"
http://That.Homepage.dk/Img/Optical_Smoke_Detector.jpg
You need to mount the pair in a way so they cannot see each other, but just the light reflected from the smoke particles - use baffles for that.
http://That.Homepage.dk/Img/Smoke_Intensity.png
Make sure the "funnel" covers the entire output of the filter (turn it upside down for the input to the filter).
You'll need to calibrate the outputs to get reliable results of course.
    • My-Blog
Re: Smoke Sensor
« Reply #9 on: June 21, 2009, 01:25:56 AM »
Okay, so fire alarm use combination of IR led and IR photodiode...humm that's very helpfull, because i don't know fire alarm use that..thx
