Author Topic: Axon 3.3v pinout --- Help Required  (Read 3243 times)
Offline salirazaTopic starter
« on: August 23, 2009, 11:28:29 PM »
Hello,
On the Axon board, right next to the USB (UART1), there is a three header pins [-,+,?] - is ground, + is 3.3v, I need to know about the ? third pin .... is it grounded or connected to the PCB circuit in anyway.
I want to use it for an additional 3.3v pin by jumping + pin to ? pin ....
Any help will be appreciated.... thanks
Ali
Re: Axon 3.3v pinout --- Help Required
« Reply #1 on: August 24, 2009, 12:32:20 AM »
i don't think so, i think it is just for ease of use with both 3 pin and two pin connectors...
the datasheet for the axon doesn't show anything being connected to it...
maybe just check if it is connected with a multimeter to be sure?
« Reply #2 on: August 24, 2009, 08:25:08 AM »
Its unconnected.
The reason is your typical Hitec style connector is ground, power, signal/disconnected. This way if you plug it in backwards, nothing will break.
