Author Topic: control 230V ac  (Read 3753 times)
Offline karmaxTopic starter
control 230V ac
« on: December 09, 2009, 07:39:29 AM »
i have 5v output from my sensor by which i want to control 230 V ac .i want to switch off or switch on using that 5v .it takes 25ma current only.please help me regarding the same thanks in advance
Re: control 230V ac
« Reply #1 on: December 09, 2009, 08:19:21 AM »
The simplest and safest way is with a relay. This provides total isolation between your controller and the AC mains.
Re: control 230V ac
« Reply #2 on: December 09, 2009, 08:47:10 AM »
Yes, but use an SSR (Solid State Relay) with zero cross shift, then the noise will be the minimum possible and the sensor won't need further circuitry (as it would with a regular relay).
Re: control 230V ac
« Reply #3 on: December 09, 2009, 08:50:34 AM »
i have to control ac voltage but my controlling signal is dc.will relay works...
Offline BEAMer
Re: control 230V ac
« Reply #4 on: December 09, 2009, 10:40:37 AM »
yes very well...
use a transistor as a switch to control the relay coil. Your 5 V DC can switch the transistor ON and OFF..
BEAMer
Offline BEAMer
Re: control 230V ac
« Reply #5 on: December 09, 2009, 10:43:01 AM »
I just did a google image search and found this.
http://interactive.usc.edu/members/phoberman/relayCircuit.gif
This is what i am  talking about
BEAMer
« Last Edit: December 09, 2009, 10:44:16 AM by BEAMer »
Offline definitionofis
Re: control 230V ac
« Reply #6 on: December 09, 2009, 10:50:49 AM »
Also, a thyristor (triac) can turn on AC with a very small DC current source.
The only snag is that is stays on until the AC goes to zero and resets the device.
You might like that functionality, like a latch.
http://www.technologystudent.com/elec1/thyris1.htm
Here is a discussion regarding isolating the 230 VAC from the 5v circuit by using an opto-thyristor:
http://forum.allaboutcircuits.com/showthread.php?t=24187
Alternistors and snubberless triacs:
http://en.wikipedia.org/wiki/TRIAC
« Last Edit: December 09, 2009, 11:16:19 AM by definitionofis »
Offline chelmi
    • Current projects
Re: control 230V ac
« Reply #7 on: December 09, 2009, 11:03:37 AM »
A triac is two thyristors. And since it is used to switch AC, there is no observable latch effect: the current  is null every half cycle.
I used a triac to control a light with a photoresistor, it's very easy to use.
Chelmi.
Re: control 230V ac
« Reply #8 on: December 09, 2009, 11:17:05 AM »
I had a hunch I had something mixed up there.
Thanks.
Here is a mechanical relay.
It does need 72 ma to trigger it at 5V.
So you would need a transistor circuit someone mentioned above.
http://dipmicro.com/store/JS1-5V
The Triacs can trigger directly on tiny currents.
« Last Edit: December 09, 2009, 11:31:41 AM by definitionofis »
Re: control 230V ac
« Reply #9 on: December 09, 2009, 03:11:34 PM »
With one of these, you'd only need a single resistor in between and you have total optical isolation.
    • RazorConcepts
Re: control 230V ac
« Reply #10 on: December 09, 2009, 04:25:49 PM »
SSRs are very cheap and easy to use (mine required no external circuitry)
http://razorconcepts.net/ssr.html
$7 shipped from ebay  ;D
