Buy an Axon, Axon II, or Axon Mote and build a great robot, while helping to support SoR.
1. Your project seems fine, all completely possible to do.2. I highly doubt that anyone here has the time to design your robot for you, and even if they did, where's the fun in that?3. It all depends on where you look. I prefer mouser.com myself.Also, try to run the 50$ robot tutorial through google translate and see if that helps.
advice, write out the componats you need.ie, gps ect.look for tutorials on those. this site, and any other you want.and probably hack a remote controled car/tank/toy to use as a base(saves building your own) personly Id build in phases. ie, working driving control whilst teathered, then transmiting pictures, and so on. then you can spread the cost of parts over time. and not crash into stuff with too many sensitive electronics on board.also, hack up an old fax machine(gears, stepper motor, wires, metal sheet ect) or telephone no one wants... speaker + mic all wired up, even have a handset for them to talk into!pretty straight foward.
What exactly is your budget for this?It's going to cost quite a bit for the specs you want, especially if you go for the hexapod...
