Author Topic: Help with programming...  (Read 3139 times)
Offline hemanthTopic starter
« on: January 02, 2010, 05:50:56 AM »
Im new to robotics and programming. I just want a code for a simple 4 wheeled bot to either go forward or turn(by letting wheels on the Left hand side spin in a direction and the other 2 in the reverse direction). can anyone generate a code for me<any board is fine, I still havent purchased 1!> :) :) :) :) :) :)
Offline Joker94
  • Helpful? 26
Re: Help with programming...
« Reply #1 on: January 02, 2010, 05:55:51 AM »
any sensors or buttons, what do you want to activate the turn.
when i know this i'll give it a shot.
Joker94
Offline little-c
« Reply #2 on: January 02, 2010, 10:16:49 AM »
$50 robot tutorial?
turn it into a 2 wheeled 1 castor robot and you can use simple diferential drive.
then take the mcu and code from the $50 robot tutorial.
Offline Pratheek
    • Probots
« Reply #3 on: January 03, 2010, 10:26:10 AM »
I would suggest buying a programable robot kit. It would come with the board plus the code.
You will be able to more than just going forward and turning.
« Reply #4 on: January 08, 2010, 05:36:42 AM »
Joker94
Only 1 switch for keeping the entire bot on or off, no sensors :)
Offline Joker94
  • Helpful? 26
« Reply #5 on: January 08, 2010, 06:03:40 AM »
what will cause the robot to turn? or you just want it to be a sequence.
will you use servos or motors?
Joker94
« Reply #6 on: January 10, 2010, 02:35:51 AM »
servos...but every action is done manually(no sensing obstacles and turning, etc)
Offline Joker94
  • Helpful? 26
« Reply #7 on: January 10, 2010, 03:01:43 AM »
Joker94
I mean what do you want to make it turn.
A different switch?(each time you hit the switch it turns 90 degrees right?)
As you just said you wanted a swith to turn the bot on and off.
Offline rgcustodio
« Reply #8 on: January 10, 2010, 03:55:34 AM »
This turning behavior is akin to a tank (or any tracked vehicle).
Find the Surveyor C source code from their website, it might help you understand how it's done.
http://www.surveyor.com/cgi-bin/robot_journal.cgi/2006/08/
My Surveyor makes its turns like you mentioned.
